Author Topic: Quick Engine Questions - 126 BIS  (Read 2288 times)
Giles2373
« on: December 27, 2014, 02:44:30 PM »
Hopefully someone can answer two quick questions for me?
1. Is Number 1 cylinder the one furthest from the Flywheel?
2. Which way should the arrows on the cylinders be facing? Away from the flywheel? Do they both point in the same direction?
Just want to be sure before I go any further.
Re: Quick Engine Questions - 126 BIS
« Reply #1 on: December 27, 2014, 04:47:09 PM »
Hi Giles :) number one cylinder is as you say the furthest one from the flywheel. Not what you mean by the arrows though? Do you mean the ones stamped on the piston top?
Giles2373
« Reply #2 on: December 27, 2014, 06:31:25 PM »
Thanks and yes, I do mean the ones on the top of the pistons.
poxxxy
« Reply #3 on: January 08, 2015, 04:05:45 PM »
I believe the arrows should be pointing towards the timing side of the engine and cylinder 1 is the one closest to the timing also so looks like you're right :).
Giles2373
« Reply #4 on: January 08, 2015, 05:50:29 PM »
Thank you. Hopefully I've got it right then.Cheers
