Fiat 126 Chat
BIS vs Cicquecento 0.7
Pages: [
Topic: BIS vs Cicquecento 0.7 (Read 1924 times)
Konstantinov
Newbie
on:
December 21, 2014, 08:32:26 PM »
hello there
I have 126 BIS but my crown wheel and pinion are in really bad condition. Im wondering:
1. Are the gearbox from Cinquecento 0.7 is the same as BIS?
2. Can crown wheel and pinion from CC get fit in to BIS?
3. How many tooth has CC pinion?
4. Which one of them is better gearbox?
Administrator
Re: BIS vs Cicquecento 0.7
Reply #1 on:
December 21, 2014, 09:45:14 PM »
As far as i am aware they are both the same, They both have the higher final drive
Pete.
il cavallo piccolo
Konstantinov
Newbie
Reply #2 on:
December 21, 2014, 09:51:26 PM »
but is it possible to swich patrs between ?
and CC engine turns on the opposite side.
Administrator
Reply #3 on:
December 21, 2014, 10:09:04 PM »
Good point Kon, but I wouldn't of thought that would be a problem with the differential or the gearbox, the straight cut 1st gear and the syncro rings should work in either direction.
Pete.
il cavallo piccolo
Konstantinov
Newbie
Reply #4 on:
December 21, 2014, 11:06:10 PM »
so can i take parts from CC and put em in to BIS ? Or I should take the whole gearbox and replace it ?
Administrator
Reply #5 on:
December 22, 2014, 12:02:22 AM »
We never had the CC700 over here in the UK, I would compare both boxes and use the parts necessary to repair the Bis box, unless after inspection they are identical then pick the best one.
Pete.
il cavallo piccolo
Konstantinov
Newbie
Reply #6 on:
December 25, 2014, 12:22:50 AM »
merry christmas to all
about the pinion and the crown from cinquecento - they are made to rotate in the opposite direction - they just dont fit
Pages: [
Fiat 126 Chat
