Dear all,
I think I have now pretty much decided the gearbox is the source of my severe 1st gear judder as everything else has been ruled out now (as best as I can anyhow). I think the crown wheel and pinion are skipping under load either due to wear in gears or the output shaft bearing allowing the pinion to move..
Thus, I have pulled apart my spare gearbox, cleaned it up and been pleasantly surprised at how good it is. All bearings are pretty much perfect and the layshaft even looks OK to reinstall. The first and reverse gears are a little mangled so I will replace those along with the slightly scored 1st gear selector. All other gears and differential look perfect and the synchro hubs all look good. The input shaft is worn where it runs in the bronze bush so thats going to need changing as well. 126Fan is going to get an order pretty soon so I would welcome comments based on the attached photos (assuming they appear OK). I would also welcome any tips from anyone who has done one of these boxes. I've done a few motorbike boxes but not a car one before!
Thanks,
Keith
