Author Topic: 126 Polish Built Air Cooled Engine  (Read 1767 times)
Vitesse
« on: November 21, 2014, 10:36:19 PM »
Hi am a newbie here and my name is Tony and live in Kent. I currently own a 1966 500F that I have owned for over 20 years and it is as original as you could get and looks like new after a recent rebuild.
I was offered a 650 engine out of a 126 and a synchro gearbox for a price I couldn't resist. I don't want to put it in my 500 as I want to keep that one original. It is clearly from a Polish built 126 and is fitted with Nanoplex ignition and the engine looks it is in really good condition, appears to have good compression. From what I can gather from the Internet, as it is fitted with Nanoplex it is probably from a 126 EL????? The Nanoplex is blue btw. It also has a cut out box which from what I have read on a German forum is not needed if it is to fit in to a 500. I trying to get some idea of age of the engine. When did they cease production of the air cooled 126 in Poland. Also it has a solenoid on the carb, from what I have also read this needs to connected to the 12v switched ignition supply.
I want to bench test if first so I want to extract what I need from the rear wiring loom that I have been given. From diagrams I have seen all I need to is the Nanoplex control unit the vacuum switch, the wasted spark coil and the to connect up as per the diagram I have seen.
The plan is to probably put into a future project 500 to give it a little ooommmppphh!!!!
Tony
