Author Topic: Shhhhh!!! They listen you know.  (Read 2544 times)
baron_matt
« on: November 19, 2014, 10:48:50 AM »
Last night on a journey home after several weeks of daily use, my girlfriend who was driving made the mistake of saying how well the 126 had been running.
I tried to stop her and I read aloud sections from the Haynes to appease the FIAT God.
This morning however it seems that my devotions were in vain as the 126 wouldn't start The issue seems to be that the new genuine FIAT starter cable fitted back in September appears to have stretched and is not pulling the starter lever far enough to make contact.
How this has happened over night is really strange.
When fitting the cable I replaced all plastic clip things and the cable still has tension, it just doesn't pull the lever far enough. What should I check?
DeVilleChris
    • Club 126 UK
Re: Shhhhh!!! They listen you know.
« Reply #1 on: November 19, 2014, 11:03:53 AM »
I've had this issue, it wasn't the cable it was the worn starter, The piece where the lever pulls had worn. I bought this piece from ebay....
http://www.ebay.co.uk/itm/Anlasserschalter-Fiat-500-F-R-126-new-starter-switch-/360727962185?pt=DE_Autoteile&hash=item53fd0fe249
and it worked fine.
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
« Reply #2 on: November 19, 2014, 11:52:28 AM »
On the starter motor cable end you have a choice of three hole settings to put the split pin through, kind of a crude way of tensioning the cable. Check it out you may be able to take up the slack  :)
baron_matt
« Reply #3 on: November 19, 2014, 12:21:55 PM »
I'll check the clip underneath as well just to be on the safe side.
The cable is on the last hole at the starter motor so I can take it up a notch to see if that works, just want to check that there's nothing else come adrift.
Good to have you back Dave. ;-D
baron_matt
« Reply #4 on: November 19, 2014, 12:22:57 PM »
and it worked fine.
Cheers Chris I'll check everything.
baron_matt
« Reply #5 on: November 24, 2014, 02:09:42 PM »
Fixed.
Really odd, the brass top hat that should sit on the front side of the plastic starter cable clip, was sitting on the engine side.
Cable clip looked fine, not broken. So undid cable and reassembled in the correct order. The brass top hat must have pulled through the clip somehow.
baron_matt
« Reply #6 on: December 02, 2014, 10:59:03 AM »
Here we go again.
Noticed last week that the starter lever needed to move further and further before the starter operated so took another look underneath.
Much to my surprise the brass top hat (outer casing ferrule) of the started cable is indeed passing through the plastic clip mounted under the heater duct (engine end).
What the hell?
It is almost as if the clip is expanding/softening as it gets hot allowing the cable to pass through it.
I've ordered up a new metal version of the clip in order to try and stop this issue from reoccurring. Has anyone else experienced this?
