Author Topic: Thousands of New Parts FIAT 126, 500  (Read 2868 times)
Piotross
« on: November 09, 2014, 04:01:15 PM »
Hello, I have to offer thousands of new, factory parts to FIAT 126 and 500. It's a problem to make a list of parts because there is a many, many, many of them, everything is new !
- interior dashboard - 1x
- set of caps Polski Fiat - 4x
- cord of gas - x5
- set of triangular windows (left and right)
- front lamp - 1x
- pedal of gas - 1x
- set of drive counter - 1x
- wipers speed controler - 1x
- metal washers of exhaust - 15x
- holdfast of gas - 10x
- oil pomp - 1x
- set of gears of oil pomp - 1x
- intake and exhaust valves -20x
- set of crank bearings I cut - 1x
- set of bearings of alternator - 5x
- fornt rockers - 2x
- timing cover - 2x
- cover of engine and gearbox- 1 x
- Pistons after modification to Fiat 126 and BIS, timings after modification, complete sets of engine
repair KIT
This is only a little part of list form every parts :) There is many, many gaskets, bolts to engine, gearbox, bolts of head, brakes, springs of engine, brakes, gearbox. Lamp shades, rubber gaskets of absorbers and rear springs. Copper gaskets of cylinders etc.
If somebody want buy something just please look a part of photos and write me and I can find this part and make a good price.
Greetings,  Piotr
Piotross
Re: Thousands of New Parts FIAT 126, 500
« Reply #1 on: November 10, 2014, 01:32:36 PM »
I also have new head Cinquecento 700 (has a bigger intake valve seats) - plug and play to BIS
poxxxy
« Reply #2 on: November 10, 2014, 05:36:10 PM »
Awesome work Piotr :). Do I get comission for getting you over here? hehe. Just kidding of course! My bis is running wonderfully for now... but I will need to retorque the head soon... and that may involve a few more pieces along the way... camshaft perhaps!
Piotross
« Reply #3 on: November 14, 2014, 08:51:02 AM »
I also have in stock new complete set of timings to 126 and BIS
« Reply #4 on: January 15, 2015, 10:29:28 AM »
Do you have a pair of rear shock absorbers for a 126 Bis?
« Last Edit: January 15, 2015, 10:41:01 AM by Amateb8 »
Danielo396
« Reply #5 on: January 19, 2015, 09:48:43 PM »
Cześć po tym jak zobaczyłem ze masz na imię Piotr to wiem ze jesteś z PL :D no nic potrzebuje kilku części a mianowicie zderzaków chromowanych, torby na wode do spryskiwaczy oraz same te końcówki spryskiwaczy, potrzebowałbym tez tylne światła najlepiej od bambino czyli te trójkątowe. tez bym byl zainteresowany wydechem do bis-a. z góry dziękuje
nathanfiddes
« Reply #6 on: January 20, 2015, 09:09:24 PM »
Do you have out rubber boots for driveshaft (dust covers) and a locking washer for front hub?
