Fiat 126 Chat
Valve adjustment - TDC marks??
Pages: [
Topic: Valve adjustment - TDC marks?? (Read 2115 times)
Bolek
Member
on:
November 09, 2014, 10:24:37 AM »
I want to adjust the valves on my 98 Maluch Town. any DIY's online?
how do I find TDC? where are the timing marks?
Subscribers
Re: Valve adjustment - TDC marks??
Reply #1 on:
November 09, 2014, 10:47:16 AM »
The timing marks are by the pulley. There's a line in the crank pulley and an arrow on the engine casing. If you remove the spark plugs and put the car into 2nd gear you be able to turn the engine slowly by rocking the car untill the marks line up. If you place a thin screw driver into the spark plug hole you will know that the piston is at the top. That is TDC.
GET SOCIALBLE. Instagram me on _gadge_
Bolek
Member
Reply #2 on:
December 08, 2014, 10:48:11 AM »
thanks! I found the mark, pretty straightforward.
lined up marks by pushing car in 4th gear (even easier).
checked valves (some where closed, 2 were not - adjusted those).
One more revolution to line up marks again.
Checked second set of valves
Pages: [
Fiat 126 Chat
