Author Topic: GUIDE: how to remove your BIS engine at home  (Read 4823 times)
« on: November 01, 2014, 08:10:03 PM »
I've had an oil leak ever since I fitted my rebuilt "green" engine in June. the culprit? the rear crank seal. So seen as its an engine out job I thought i'ld do a guide just to show others who are thinking about doing it themselves but are not sure about how to go about it. its really simple and can be done anywhere with a bit of flat land and some basic tools. the way i'm going to show you is not gospel its just the way i've been doing it for years but I'm sure other will have done it a very similar way. ok so here we go :)
first up get your car in position. it wont move again so make sure its not in the way like mine was  :D
next is to get the back end up and set it on some axle stands and disconnect the battery. once this is safely done remove the guard under the radiator (if it still has one) and undo the clip holding the bottom and the heater hose. remove the hose and the smaller (but not the smallest) heater hose slowly to drain the coolant in a suitable container. the fluid in the picture below is clear as its prep fluid that's been in there for a week as i'm going to be refilling with waterless coolant.
ok whilst that's draining out its time to remove all the guff on the top. start on the right by removing.....
the air cleaner assembly,
remove the choke and throttle cables from the carb,
remove the HT leads and vacuum pipe,
remove the hear hose from the three way junction that disappears into the car (the one in the middle as you look at the junction),
remove the earth strap to the body,
remove the thermostat wire from the top of the junction,
then go to the left and.......
remove the top hose from the radiator,
undo the alternator wiring (the small 10mm nut and the push on connector)
undo or remove the distributor wire that goes to the coil,
undo and remove the two fuel pipes from the fuel pump
remove the oil pressure wire at the bottom.
nearly there. i'm planning on leaving the gearbox in the car so you will need to remove the starter motor. undo the wires on the back by unscrewing the big nut with the large cable on it and pulling the push on connector out from the solenoid (mine had a cover on the back which also needed to be removed). once done you can remove the three 13mm bolts that hold it in place and remove it out of the car. whilst your under the car you can remove the other two nuts that hold the engine to the gear box. leave the top two for now. there's also a small cover on the left that covers a small part of the flywheel. remove this too if its still there.
your on the home straight now. loosen (but don't remove like i've shown lol) the four 13mm bolts that hold the rear panel on. there are two on each side at the far edge of the panel. the two by the cylinder head are the easiest the other two on the other side are hidden by all the hoses and wires. while your there un plug the wires for the number plate, rear fog and reverse lamps.
next is to remove the four 10mm bolts that run along the top of the panel.
because i've been doing this a while i'm going to be using a hydraulic motorcycle lift that i've adapted with wood especially for the job but a trolley jack can also be used in the same way with some wood and some rope to tie to the engine - I know this works as i've done it  :D
because i'm using the lift I removed the exhaust but if your using a trolley jack you wont need to
now the fun part  ;D position your jack/lift under the engine right in the middle where its best supported and raise your jack/lift so it just touches. now remove the rubber grommet on the top panel and you'll see a 13mm bolt. you'll need a long extension to reach it. this is the rear engine mount bolt. remove it and extract it out with the spring and rubbers
then remove the four bolts that you loosened previously mentioned that hold the rear panel on and carefully remove the whole rear panel - including the bumper so you should be left with something like this
now remove the top two bolts that hold the engine to the gear box and carefully pull the engine from the rear of the car making sure that nothing is still attached or snagged on the way and "Roberts your fathers brother" its out"  ;D
now go stick the kettle on and break out the biscuits  ;D
to refit it is just a matter of revering what I showed you. this took me around two hours and that was taking my time with photos aswell. there really isn't anything to be scared of with these engines and its quite rewarding when you have finished it....... there are not a lot of cars that you can do this to theses days......sadly  :(
« Last Edit: March 31, 2019, 08:56:57 AM by Gadge »
dom.kellett
Re: how to remove your BIS engine at home
« Reply #1 on: November 01, 2014, 11:02:21 PM »
I did mine the same way but pulled out my gearbox too as I was checking all of that aha, great descriptions too etc.
« Reply #2 on: November 02, 2014, 01:45:47 PM »
To be fair I usually do but on this occasion I didn't really need to as I knew what the problem was so thought I'ld agave a go at leaving it "in situ"
dom.kellett
« Reply #3 on: November 02, 2014, 08:22:41 PM »
Yeah, was u good job I toke it out though, the rubber bushed were dead aha hope this has helped a few people, I will certainly help me next time as I didn't know about the rubber bung for the main bolt, I did it at the most awkward angle ever and then got crushed fingers from the spring lol
Guldbergdk
Re: GUIDE: how to remove your BIS engine at home
« Reply #4 on: November 18, 2019, 12:03:52 PM »
Hi Gadge
Nice guide. Seems like the photo have disappeared. Do you have them lying around?
« Reply #5 on: November 18, 2019, 08:21:45 PM »
Hi guldbergdk. Sadly for many years I was using photobucket to upload my photos on here but they decided to start charging people to upload them. They did allow me a "free" amount of storage just out of courtesy but I managed to exceed this very quickly. Because of this all my previous images went blurry so I deleted the account. I could of course just downsize the photos and upload them onto here manually but I don't actually own a computer. Everything I post on here is don't via an IPad or a phone so I don't know how to do it (not very tec savy)
Njkip
« Reply #6 on: November 18, 2019, 09:11:06 PM »
Hi gadge, thanks for the info and uploading the pictures very interesting and helpful...was just wondering, is there a significance to the "green" engine? And it was nice to see the radiator guard plate still there....I've been looking for one for mine...🤔 Your car looks awesome ..👍
« Reply #7 on: November 19, 2019, 10:31:05 AM »
Gadge if you sendme the photos to my email [email protected] I will resize them and add them to your original post.
