Author Topic: Fiat 126 Battery  (Read 2754 times)
baron_matt
Fiat 126 Battery
« on: September 02, 2014, 11:49:21 AM »
I'm thinking of getting a new battery for my 126 as the previous owner had fitted the wrong size one which means its not properly secure.
Can anyone advise what the recommended battery is for the 126?  I've seen on ebay listing for Bosch S3 077, is that correct?
Also how is the battery supposed to be fixed down?
poxxxy
Re: Fiat 126 Battery
« Reply #1 on: September 02, 2014, 12:03:40 PM »
Would love to know this myself to be honest... atm i'm using an MR2 battery and its a little big for the tray... also unsure on how the hell a battery clamp would work :). Wondering if I can just wedge it with the spare wheel as others have managed to lol.
rick
« Reply #2 on: September 02, 2014, 12:23:31 PM »
When I completed my rebuild last year, I simply measured the battery space, nipped down to Halfords with my tape measure and found a perfect fit. Yes they are bolted down, there is a small nylon clamp which sits at the lower inboard end of the battery with a bolt through it into a captive nut on the battery tray.
baron_matt
« Reply #3 on: September 02, 2014, 12:53:14 PM »
Don't suppose you noted the code on the battery you fitted did you?
andyzeetec
  • 126 BIS
« Reply #4 on: September 02, 2014, 12:54:44 PM »
Bosch S3 077, thats the one.. I bought one off ebay a while back 50quid. (I believe they are a special as the +/-poles are opposite ends to standard )
just to confirm.. Axel are showing them on their site aswell...
http://webshop.fiat500126.com/katalog/artikelinfo/6421/battery_bosch_s3_12v-45ah_205_x_17_x_19_filled
rick
« Reply #5 on: September 02, 2014, 04:25:16 PM »
The battery I got has 'Halfords HB 063' written on it, and seems to have all the power you will ever need for a 126.
poxxxy
« Reply #6 on: September 06, 2014, 08:24:22 PM »
Turns out I've got an 063 from an old fiesta which fits perfectly, so the MR2 can have its huge thing back. Although this 063 has been outside for 2 winters at least and is a bit older than that lol.
