Author Topic: Anyone fitted an electronic ignition module to there 126? Or maybe megasquirt?  (Read 1507 times)
poxxxy
So...
I've been reading... and filling my head with ideas. Seems theres a few people around the globe who have fitted Nanoplex ignition modules (210A/211A/213A (the one I'm interested in the most because configured to 10 degrees BTDC) from the 126ELX and CC700's. I'm kind of tempted... can do away with the distributor totally but I believe you need a coil with igniters built into the coil? I then came across APE in Opole, Poland who make a 20ff ignition module with some upgrades (no rpm limit, and increased spark) and I have seen it in recommendation for use with E85 fuel due to being able to change the timing fairly easily. I wonder also if I could read the eprom from any of these ignition modules and check/edit the spark ignition maps for myself. I forgot but there is also a pressure valve connected to the inlet manifold (but its simply a switch for if pressure drops below 150mbar I think to determine high/low load spark maps), easy enough I guess!
I guess problems are mounting the sensor and a trigger wheel...
Then... all of this, I'm wondering whether if going that route and losing the purely mechanical aspect of the car it would be worth perhaps going for a megasquirt... using a throttle body arrangement (I noticed DEYAN IYI mentioned the cc700 manifold for DCOE carbs previously on a post)... so perhaps I could run two injectors... two throttle bodies, one for each cylinder and have a wideband lambda in the back to control the fueling. But then I'd want a turbo too :D.
Of course... I may not bother with any of it, but it certainly does interest me and having the knowledge would surely push me towards doing something with it :D.
I would love to be able to tune my bis using modern EFI. I'm unsure on megasquirts capabilities regarding control of a turbo though to!
Mics126
it should be ok with a turbo as long a you have a map sensor tat reads both vacuum and pressure and a preset map i the ecu for the same vacuum and pressure.
I'm pritty shore but don't quote me on this that someone on anther forum i'm a member of (Opel Manta Owners Club), one of them are running mega squrt iinjection an i'm pritty shore its turbocharged.
My main advise is do reserch and then decide what you ca do and what you then want to do.
Mike
