Author Topic: 999....brake drum bolts  (Read 1611 times)
AlGore126
« on: August 30, 2014, 03:19:25 PM »
i guys..i am trying to remove the front drums front my 126 bis.... do you know if the locating bolt... long one with a point on it...goes into the hub aswell as the other bolt... having real problems trying to undo it so was just making sure it was necessary to remove it... my have to be drilled out..are replacement bolts easy to get hold of. regards alex
Re: 999....brake drum bolts
« Reply #1 on: August 30, 2014, 03:41:28 PM »
alex looks like the location bolt is threaded into the hub.
« Reply #2 on: August 30, 2014, 06:59:43 PM »
andyzeetec
  • 126 BIS
« Reply #3 on: August 30, 2014, 10:50:01 PM »
If the hex is rounded off, try mole grips on the pin.
