Author Topic: Bis - Oversize Pistons for boring out...  (Read 2646 times)
poxxxy
« on: August 05, 2014, 09:30:02 PM »
My block/pistons look a little worse for wear and engine is burning oil as soon as its warm... I can only assume that its related. But I think the current block will only be good for boring out (and if going that route... bigger pistons and more displacement sounds like the way to go!) or maybe inserting new liners if they're available?
I assume aircooled pistons would be fine in a water cooled engine and are generally tougher.
Re: Bis - Oversize Pistons for boring out...
« Reply #1 on: August 06, 2014, 07:03:51 AM »
possibly just get the bore re-honed and have some oversize piston rings?
« Reply #2 on: August 06, 2014, 09:46:53 AM »
 It seems anything for a bis engine is difficult to get. Your best bet would be Poland for either oversized pistons and rings, or new liners and standard pistons.
 The air cooled pistons won`t fit.
poxxxy
« Reply #3 on: August 06, 2014, 11:33:04 PM »
http://www.turismo-veloce.com/en/engine-parts/32-pistons-set-82mm-750cm3-engine-126-126a-et-126a1.html
If the water cooled pistons fit in the air cooled... wouldn't these fit? :).
« Reply #4 on: August 07, 2014, 07:48:17 AM »
 The problem is that the Bis pistons are shorter than the AC ones, so they probably won`t fit.
poxxxy
« Reply #5 on: August 07, 2014, 09:05:30 PM »
Hmm nanni ricambi recommended there 82mm pistons and 130mm con rods... piston supplied would have 12mm taken off the compression area I to counter act the 12mm greater on the length of the con rods.
