Author Topic: Ethernal question-lead additive?  (Read 1648 times)
Clancy_Ryan
« on: July 27, 2014, 02:19:56 PM »
Hi everyone!
I've got a 1990 aircooled fiat. My problem is should I use lead additive. Thing is engine was completely rebuilt some time ago, but I don't have any contact with the guy who done it.
So I don't know if the valves been prepared to use unleaded or not.
So the big question is- Should I use additives, or is that going to do more damage if the engine is now for unleaded. I'm not gonna do many miles in it a year, certainly no motorway driving.
Thanks.
Mics126
Re: Ethernal question-lead additive?
« Reply #1 on: July 27, 2014, 05:44:04 PM »
it's best to use the lead replacment just in case because you will never damage the engine with it even if its had the valve seats changed but if you don't there is always the possibility of causing issues.
124cso
« Reply #2 on: August 02, 2014, 03:27:26 AM »
Simple fact of the matter is that they have an alloy head so will all have steel (or cast iron ?) valve inserts fitted as standard, so theoretically no need for additives or leaded fuel.
HOWEVER ; The owner's manual I have says exactly that, then goes on to say that for long life, "every third tankfull should be leaded fuel" !!! So ?????
I got hold of a box lot of fuel additive as dead stock ex a retail shop / fuel station - for next to nothing so put that in with every second or third fill. I did notice that the tendancy my car had for overrun / shudder at switch off has mostly gone. Coincidence??, wishful thinking???
