Author Topic: Daily Driver?  (Read 2754 times)
Rory126bis
Daily Driver?
« on: July 18, 2014, 01:57:24 AM »
Hi everyone I'm very new the the fiat 126 scene and was hoping those with a little more expertise could help me out.
I'm 17 and recently bought myself a 1989 126bis (38,000 miles). The car runs and drives but (engine and gearbox good)  not very well  :lol: At the moment I have the 126 up on a ramp where I have totally stripped the interior, replaced the leaf spring, king pins replaced and have just started to weld the car (which will take a long time).
Anyway what I was really wondering is if a fiat 126bis could be used as a daily driver as I am moving to Aberdeen to start work in OG and really need to be able to get into work without having to worry too much.
Any advice or knowledge on reliability of the bis as a daily driver would be much appreciated
Thanks Rory.
Re: Daily Driver?
« Reply #1 on: July 18, 2014, 06:53:00 AM »
Once you've got the engine running sweet like setting the timing up properly and giving it a bloody good service then there's no reason that it can't be your daily driver. The most important aspect of the BIS is it's cooling system. It needs to be 100% perfect in every way so maybe stick a new thermostat on and some fresh coolant in it then bleed the system properly or it will quickly blow its gasket. It's the BIS weak spot they go ridiculously quick once they over heat.
I've got a BIS and it's my daily driver. I don't do too many miles a year but I do find myself constantly fiddling with it to keep it in fine tune as I'm paranoid it's gonna fail if I don't. That's the thing with this cars unlike modern cars where you expect to do many miles without even checking under the bonnet, with the 126 they need constant attention to make sure that they will last.  :D
Rory126bis
Re: Daily Driver?
« Reply #2 on: July 18, 2014, 02:35:33 PM »
Reassuring to hear someone actually runs their bis as a daily driver haha! Thanks for the advice I'll be sure to replace the coolant and thermostat in that case!
Can't wait to drive this things properly! Just a matter of time before I've gotten it welded, re-sprayed and all the new parts fitted  ;D
Re: Daily Driver?
« Reply #3 on: July 18, 2014, 05:53:08 PM »
Hi Rory , welcome to the world of the 126  :D
If you stick with it I am sure that it will be an experience that you will never forget. Like any vehicle that has ever been made the 126 was designed to be driven and not break down. Most of the problems with these cars come about because the cars have been neglected , bridged in some way or been left standing for a long period so things deteriorate. There are cars out there that have covered over 100,000 miles and are still going strong because they have been looked after. So I would say do as much shaking down as possible before you have to rely totally on the car  :)
Re: Daily Driver?
« Reply #4 on: July 18, 2014, 08:23:26 PM »
I second that just keep an eye on things - give it some TLC every other week by keeping on top of oil changes and the points. It will look after you if you do  :D
chrisrhodesinlbz
Re: Daily Driver?
« Reply #5 on: July 18, 2014, 09:05:13 PM »
I have had my BIS for 5 years, but have another car too (a Merc CLC). I have recently changed jobs which meant instead of a 135 a day mile round trip it is only about 60. I love my 126, and thought I might use it for my new commute which is a mixture of country lanes, dual carriageways and the M25.
Hate to say it, but my BIS crashes through potholes on the country roads, struggles on the hilly bits of the dual carriageways and motorways when there are lorry drivers and slow cars where you lose momentum. It is not really a commuter car (was it ever meant to be?) so I now only take it on Mondays and Fridays.
The twice a week outing is great to maintain everything, but I don't think the 126 was ever meant to be a long-distance car.
Rory126bis
Re: Daily Driver?
« Reply #6 on: July 18, 2014, 10:30:43 PM »
This all sounds very reassuring, I think after hearing this I will after all be using this.  And the car itself will be used in Aberdeen doing a very small commute like 20 miles most per day. I did buy this car with the intention of getting it MOT'd and sold but the more repairs I did oddly the more I wanted to keep it haha!
I did try posting photos of my car on the restorations page but the files were too big, but I'll find a way and show you all how it's going!
Re: Daily Driver?
« Reply #7 on: July 19, 2014, 03:39:57 PM »
I'ld just like to say that today I covered a 270 mile round trip from Warwickshire to tiptree in Essex and it didn't miss a beat  :D it sat at 55 -60 mph all the way and cost me around £25 in fuel. It wasn't the most comfortable journey as they kind of "hum" and after a while it grates on you. There's a good an mount of room in there to stretch you left leg out but you right one does seize up after 2 hours. Ride quality is choppy to say the least and when the wind picks up you ind yourself fighting with the wheel. But for a small journey like a commute to work then it's perfect!
I personally think it's the perfect commuter car and plodding though towns and duel carriageways at 40-50 mph is what it does best. it's designed for economy not speed and comfort levels are "adequate" in that there's a seat a steering wheel and all the controls at your finger tips just like a bicycle has a seat and a couple of good tyres - it's functional :D
baron_matt
Re: Daily Driver?
« Reply #8 on: July 19, 2014, 11:53:45 PM »
Also the top tip is don't get disheartened if it takes a while to get it right. we'd had our 126 since March and we are still shaking down the issues, built up over 30 years of neglect.
We will get there and every day it is better than the last :-) So keep at it, cos they are great fun and not as obvious as a mini but handle just as well. :-)
