Author Topic: aaaaggggghhhhhh brakelights dont work  (Read 1359 times)
chad123
« on: July 06, 2014, 07:45:32 PM »
 :( can anyone help please, my brakelights dont work
ive changed the bulbs, switch, fuses and nothings happening
Re: aaaaggggghhhhhh brakelights dont work
« Reply #1 on: July 06, 2014, 08:21:54 PM »
Hi chad,
If you have a multi-meter, check you have 12+ volts on the brake switch, make sure that its adjusted properly there should be a gap between the switch and the brake pedal when pushed down, check you have 12+ volts on the other side of the switch,
If you have work your way back to the back brake lights, Also check the earth on the rear light units.
popik81
« Reply #2 on: July 06, 2014, 08:56:59 PM »
check a plug under the brake pedal, its like to disconnect :)
poxxxy
« Reply #3 on: July 07, 2014, 10:31:37 AM »
Also multi-meter on the rear light connections whilst someone is pressing the brakes... see if you have power there... the pins in the connectors may also needed prising out gently to make a better contact if everything else checks out!
