Author Topic: 126 hand throttle  (Read 2378 times)
baron_matt
126 hand throttle
« on: June 18, 2014, 05:04:48 PM »
I have heard a rumour that 126's had hand throttles like the Fiat 500. Is this true?
How did it work and where was it fitted and did it ever get fitted to RHD UK cars?
Matt
Re: 126 hand throttle
« Reply #1 on: June 18, 2014, 08:53:29 PM »
A hand throttle?? As and addition to the floor one?
wsmitwil
« Reply #2 on: June 18, 2014, 09:16:39 PM »
Yep the 70s ones could be fitted with a hand throttle, essentially a wire that looped around the accelerator pedal and linked up to a little pull handle under the steering wheel, exactly like the 500, which acted like a cruise control
One that was turned into a racing 126 that the bloke striped down to the bare shell, which I had all the parts off had one in, I thought about fitting it to my blue 126 but I ended throwing it in a box in the garage somewhere
 you can still buy them from axel gerstl :
http://webshop.fiat500126.com/katalog/artikelinfo/2157/throttle_hand_lever_assembly
« Last Edit: June 18, 2014, 09:18:39 PM by wsmitwil »
fiats forever
baron_matt
« Reply #3 on: June 19, 2014, 01:48:52 PM »
So does anyone know how this cable was routed on UK RHD cars?
How is the finger pull held in place?
Matt
« Reply #4 on: June 20, 2014, 08:39:49 PM »
Other was bracket welded to the central tunnel, the same as a fiat 500.
Bar Vitelli
« Reply #5 on: June 20, 2014, 09:10:50 PM »
I've got one on my cars but I've never dared use it!  :o
Every cloud has one...
baron_matt
« Reply #6 on: June 20, 2014, 10:30:33 PM »
So can anyone show me a pic of one in situ on a RHD uk car?
Just interested to know where it would mount. On a RHD car the throttle would it be very much over on the right hand side or still in the middle?
cheers
« Reply #7 on: June 21, 2014, 10:03:57 PM »
It is in the middle of the front central hot air duct close to the Y branch for the demist tubes. I will try to take a photo tomorrow.  Bar Vitelli I used mine in my old 500 on the motorway a lot.
