Author Topic: suspension blocks  (Read 2252 times)
gammakeith
suspension blocks
« on: June 17, 2014, 06:38:46 PM »
Can anyone advise what the probability of shifting the aluminium leaf-spring mounting blocks will be?  They appear to be pretty much corroded hard onto the studs?  The reason is that I am wanting to make up some brackets to mate up to a towing A-frame that I got cheap.  That way when we go on holiday with the motorhome we can tow the little Fiat behind the big Fiat  ;D     However, for obvious reasons its all got to be secure so my plan was to remove the alloy blocks and sandwich the fittings underneath.  If I reduce the height of the blocks accordingly then I can preserve the ride-height.  However, if removing the blocks will be impossible without destroying them (or the studs) then I may need to think again.
Thanks,
Keith
Re: suspension blocks
« Reply #1 on: June 17, 2014, 07:34:58 PM »
Hi Keith, Go round the retaining nuts/threads with a stiff wire brush once you've cleaned them up spray them with penetrating oil or wd40 let it soak in for a couple of days then you should be able to remove them without a problem, remember the spring is under load and can cause injury so be carefull :o
« Reply #2 on: June 17, 2014, 08:58:16 PM »
I had the very same issue only last weekend when I fitted my shorter ones. I used a blow torch. Not for long but it was enough to expand the studs and break the corrosion that grips them :)
gammakeith
« Reply #3 on: June 18, 2014, 07:03:58 AM »
Hi Guys, thanks for the input.  It sounds like its going to be worth a try to shift them.
Keith
« Reply #4 on: June 18, 2014, 10:52:11 AM »
If you do get them off give the studs a going over with a wire brush then coat them with copper grease before you refit :)
baron_matt
« Reply #5 on: June 18, 2014, 11:16:20 AM »
If you are just changing the spring, should you remove the blocks?
jokke
« Reply #6 on: June 18, 2014, 01:38:36 PM »
Better use alu grease og ceramic grease. Copper will react with the aluminium blocks and tear they apart.
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #7 on: June 18, 2014, 08:56:36 PM »
The blocks kind of just fall off if there not seized on so no you don't have to remove them to change the spring however I would just to break the corrosion seal that will inevitably be holding them in place.
