Author Topic: BIS Ignition switch non-repeating safety feature?  (Read 1400 times)
andyzeetec
  • 126 BIS
« on: June 04, 2014, 01:26:38 PM »
Read about this in the owners manual, it sais if the engine does not start you have to turn the key right back to the Stop(ST, steering lock) position before attempting to start it again. So I guess if you don't (i.e try and start from the MAR position) it just won't start.
Can anyone explain the idea of this Safety feature or the workings behind it, being dumb  :headscratch:, although I guess naturally you tend to set it right back to ST position anyway.
Thanks.
jokke
Re: BIS Ignition switch non-repeating safety feature?
« Reply #1 on: June 04, 2014, 10:00:54 PM »
is just a safety, so you can't crank when the engine is running. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
124cso
« Reply #2 on: June 05, 2014, 01:50:46 PM »
 Been a common feature of European cars for many years. I had a late 70's VW Kombi was like that. Main feature / desired effect is to be a pain in the arse !
