Author Topic: Tuning...again  (Read 4434 times)
mossfred
Tuning...again
« on: May 25, 2014, 05:46:05 PM »
Im new to the forum, had a modified (by MBG) 650 with FZD for many years and am building a hopefully fast motor myself this time.
I need some advice on carb and cam. The motor is a 600, i can get a new set of 650 pistons and barrels (Polish) cheap from Holland, worthwhile, or should i think bigger, dont really want to spend the$$?
Should i go for a dellorto fzd 32/26 or a solex 34 PBIC? FD offer a 40/80 300deg cam or should i go for the swiatek R385? I have a ported big valve head and light flywheel
Any good advice welcomed!!
Fred
Re: Tuning...again
« Reply #1 on: May 25, 2014, 06:15:07 PM »
Why not simply fit a 650 engine first and see what you think.
Then start modding that?
Re: Tuning...again
« Reply #2 on: May 25, 2014, 06:45:55 PM »
Hi Fred , welcome to the forum. I guess that you know that you cannot fit 652ccs barrels to a 594 crankcase without having the crankcase bored out so if you are going the 652 way you might be better off starting with a later 126 crankcase but do not go for the later Polish ones otherwise you will not have a hole to drop your distributor in. Sounds like you have the head sorted, is that a 500 flywheel you are using ?
I would suggest that you have a trawl and search through the tuning section on the forum and you may find some answers there  :)
mossfred
Re: Tuning...again
« Reply #3 on: May 25, 2014, 06:57:22 PM »
I was going to bore the crankcase. I have read every post on the forum, but didnt really find out much if anything about using the Solex/Weber 32PBIC, i have a Dellorto on my other motor but its 3 times the price of the Solex/Weber 32. As for the camshaft i found out about Swiatek on this forum but am curious if anyone has used/compared to the generic Abarth copy on offer from FD (the 40/80 300 deg cam). The flywheel is from FD and i guess its specially made as opposed to a lightened standard type!
Fred
Da Londo
    • Fiat 126 blog
Re:
« Reply #4 on: June 07, 2014, 11:59:38 PM »
Hey mossfred, I suppose you don't remember what jetset was used in that FZD?
Sent from my HTC Desire X using Tapatalk
« Last Edit: June 29, 2014, 10:07:11 PM by Da Londo »
mossfred
Re: Tuning...again
« Reply #5 on: June 27, 2014, 06:06:23 PM »
Hi Da Londo
Its been 10years since i had to re-jet it after picking it up from MBG. The car is in the bodyshop, next time i visit i will have a quick look see
mossfred
Re: Tuning...again
« Reply #6 on: June 27, 2014, 06:12:19 PM »
In case anyone is actually interested, i have built the motor now, 704 cc, 40/80 cam 2.5kg flywheel, Solex 34 PBIC on the Abarth valve cover and big valve ported and skimmed head. A lot of machine work was required to put these parts together. Will dyno it soon and post results.
Re: Tuning...again
« Reply #7 on: June 27, 2014, 09:51:47 PM »
 I`ll be watching the results with interest on this one.
 Have you actually had the engine running yet? How does it behave with such a light flywheel?
Da Londo
    • Fiat 126 blog
Re: Tuning...again
« Reply #8 on: June 29, 2014, 10:07:31 PM »
Great!
Hi Da Londo
pony007
Re: Tuning...again
« Reply #9 on: September 28, 2014, 08:51:37 PM »
« Last Edit: September 28, 2014, 08:53:54 PM by pony007 »
