Author Topic: WANTED BIS SPEEDO  (Read 3250 times)
AlGore126
WANTED BIS SPEEDO
« on: May 24, 2014, 12:01:48 PM »
HI EVERYONE... I AM LOOKING FOR A SPEEDO FOR MY BIS... NEEDS TO BE WORKING AND IF POSSIBLE WITH ANYWHERE AROUND 18K ON IT OR JUST ABOVE BUT NOT ESSENTIAL... HAVE NOTICED WITH SOME OTHERS FOR SALE THEY HAVE A FUEL GAUGE AND TYRE PRESSURE GAUGE..MINE HAS A FUEL GAUGE AND TEMP. GAUGE SO IF YOURS IS THE SAME THAT WOULD ALSO BE GREAT...ANYTHING CONSIDERED...I JUST WANT TO GET MY MILOMETER WORKING AGAIN. THANKS!!!!
Bar Vitelli
Every cloud has one...
AlGore126
Re: WANTED BIS SPEEDO
« Reply #2 on: May 24, 2014, 12:52:13 PM »
cheers im after mph if possible...the only issue with mine is the cog attached to the milometer barrel has worn teeth and wont turn anymore...do u think the kph barrel would work the same or set us differently to the mph one
emma
« Reply #3 on: May 24, 2014, 08:11:25 PM »
hi we have one maybe two but dont know mileage i will have a look over weekend and let you know, i think one still has switches on its on a G reg bis
AlGore126
« Reply #4 on: May 24, 2014, 08:20:00 PM »
thanks look forward to hearing from you..... must be the most helpful owners club forum ever ;D
markymarc
« Reply #5 on: May 24, 2014, 08:28:04 PM »
I also have 1 that has a small piece cut out of the plastic surround that some idiot boy racer was gona put in LEDs!!
I will search it out if still needed?
Marc
AlGore126
« Reply #6 on: May 24, 2014, 08:56:05 PM »
cheers I can always use the surround from mine...look forward to hearing from you.
markymarc
« Reply #7 on: May 25, 2014, 03:26:19 PM »
I have emailed you a picture, it has 25k on the clock
Marc
AlGore126
« Reply #8 on: May 25, 2014, 07:05:31 PM »
yea that looks decent.... not sure how long the milometer on mine hasn't been working for...only bought it over the winter..so it may have done 25k... rather have it over than under... where are you based and what would you want for it?? do you know if it was working before it was removed??? cheers alex
Trevor
« Reply #9 on: June 03, 2014, 06:41:00 PM »
Hi there, i have clocks in a 126 bis here, 24495 miles on clock, also has fuel and temp gauges.
Cheers Trevor.
AlGore126
« Reply #10 on: June 03, 2014, 09:20:21 PM »
sounds good do you know if it works..what do ya want for it??
Trevor
« Reply #11 on: June 04, 2014, 11:13:05 PM »
Hi, the car has been in the back yard for 3 or 4 years now, i think everything worked back then? as for cost, pm me an offer sure.
Cheers Trevor.
