Author Topic: Choke usage  (Read 1287 times)
max
  • Fiat 126elx Orange LHD 1997
Choke usage
« on: May 23, 2014, 10:46:20 AM »
Being a youngish (under 40!) person, and modern cars don't have a manual choke, so not had to use it before. (I do remember my dad still having to use a choke in the early 80s). How long do you leave the choke on for when starting your 126?
I've got a 1997 air-cooled 126, I use the choke to get the engine started for the very first time (don't need to use it once the car has been driven and the engine is still warm).
I usually leave it running for about 30 seconds (while I put my seat belt on a get comfortable, etc).
The car usually idles fine, after 30 secs of choke, but I'm wondering if I should be letting it warm up for longer before turn the choke off and driving off.
Just wondering what other people do with the choke and letting the engine warm up?
Max
Re: Choke usage
« Reply #1 on: May 23, 2014, 04:54:42 PM »
Basically if you push it in an it cuts out then you've pushed it in too early. I use mine for the first minute at least any less then it judders and sputters when I try and pull away until I pull the lever back out a little
Mics126
Re: Choke usage
« Reply #2 on: May 27, 2014, 09:31:45 PM »
As gadge said if the engine stalls you tured the choke off to early. every engine is set up differently so wht works with one person might not work with others. with my car and the work i have done to the  engine even when the temperature outside is cold and same with the engine I don't have to use the choe but if I do i run the choke for 30 secs aswell.
But before i drive off I always let my oil temp reach 50-60 degrees celcius (Obviously I have a oil temp gauge, by the way thats at the bottom of the sump because thats where i managed to it the sensor) because I drive the nuts out of my car for the start.
