Author Topic: is 126 700cc same as Cinquencento  (Read 2426 times)
john smith
« on: May 10, 2014, 08:45:51 AM »
http://www.ebay.co.uk/itm/121224328438?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 :o cause if it is. It should hope fully for straight to the his gearbox. Any one know at all. More power and cheap from the breakers yards! 8)
john smith
Re: is 126 700cc same as Cinquencento
« Reply #1 on: May 10, 2014, 08:58:43 AM »
On the auction it says early  cinquent? Are 700 cc so I am now also wondering if this is the same :o.http://www.ebay.co.uk/itm/STARTER-MOTOR-Fiat-Cinquecento-Fiat-Seicento-old-Fiat-uno-1980s-/231221695474?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35d5e313f2. Five quid. If I/had work I'd buy it just to prove or dispelled the thought. >:( just lashed pt 65 quid if it did fit ,I'm gutted.
« Reply #2 on: May 10, 2014, 09:07:12 AM »
Fiat did make a cinquento with the BIS engine. Not sure if they sold it here though?
« Reply #3 on: May 10, 2014, 09:08:41 AM »
Very nearly the same, but rotate the opposite direction, great if you like going backwards at 60mph. The rocker cover is definitely useable and better, not sure what else is worth having.
« Last Edit: May 10, 2014, 09:11:01 AM by Hazey-n-Marc »
jokke
« Reply #4 on: May 10, 2014, 09:22:02 AM »
I have just mounted a cinq 700 engine in my bis. :) So now I have a oilfilter! ;)
but you have to change over:
the camshaft
the cover in front of the engine, where the chain is.
and the block is not the same, so have to cut out a section where the starter goes in.
And i had to grind of som metall at the topp of the oilpump, where the gear goes down. because the gear that goes on the camshaft jammed.
but it fits great. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
john smith
« Reply #5 on: May 10, 2014, 09:28:54 AM »
Old be stuffing into a trike so space would not be a prob or engine mounts.  My problem is the gearbox to engine coupling and as some one here just said its rotation.
john smith
« Reply #6 on: May 10, 2014, 09:32:47 AM »
If I had the dish.I'd have the hole lot transplanted. Gearbox running gear and lump. But that's engineering work. And costs more than the trikes worth see. I might be worrying needlessly but , the engines very tight  and sat for many years.in a barn and a field. So could be dead as a dodo???
poxxxy
« Reply #7 on: August 31, 2014, 11:03:01 AM »
Very interesting Jokke... i'm still thinking about the route to tune my BIS... I could perhaps use an aircooled performance camshaft if I were to go for electronic ignition and electronic fuel pump... but then the car is far from stock. :(. I need another engine to play with!
