Author Topic: cylinder head skim  (Read 2637 times)
cylinder head skim
« on: May 07, 2014, 11:40:26 PM »
I was advised that a2mm skim for my panda head would be the optimum for a fast road engine build, any comments.  I took my panda 30 head down to my local machine shop and asked the guy for a price to skim 2mm off the head.  I was quoted £80 +. Thought this was a bit high what do you think.
Re: cylinder head skim
« Reply #1 on: May 08, 2014, 07:13:53 AM »
Hi Ralph , I have got a skimmed and original Panda 30 heads here so just done a bit of measuring. The skimmed head looks to have had 1.5mms removed which leaves about a 1mm deep gas escape groove. That cost for skimming seems a bit high to me. I would have thought about half that. I have just had some rebores done on 500 & 126 cylinders then I have had some crankshafts reground. I used two different engine machine shops as prices differed a lot at each shop for reboring and regrinding so I would shop around  :)
« Reply #2 on: May 08, 2014, 01:26:50 PM »
Rusty phoned about price ranges between £50 -£90+vat ouch! S I will be off to the Borders to a race engine service £50. Just need to decide 1.5 or 2mm.  middle Barton Garage suggested the 2mm. Anyone with more advice?
poxxxy
« Reply #3 on: May 24, 2014, 05:24:05 PM »
I paid£60 here inc valve removal etc
DEYAN IYI
« Reply #4 on: May 24, 2014, 11:52:25 PM »
According to the measurements I made 1,4mm skimming of Panda head is about 9,5:1 CR (with standard gasket) and it's the minimum for 288* (Swiatek 385) camshaft.
Swiatek says "-1,8/2,5mm head skimming" but no info for the old or for the new(same as Panda) type of head, so I had to choice the old one for a starting point, cos you can always skim a bit more any time. (I want it 700cc one day with the same head, so that's the reason for being careful).
Regards!
PS:
Fiat Abarth 595
9.5 : 1
35/75 - 290* camshaft
Fiat Abarth 595 SS
10 : 1
40/80 - 300* camshaft
