Author Topic: Sole transport  (Read 1875 times)
baron_matt
Sole transport
« on: April 10, 2014, 01:17:28 PM »
Due to a series of unfortunate events all 4 of my cars is currently off the road with the Fiat looking the most likely to be back in action after the local garage replace the rear wheel bearings and torque couplings.
I have to do a 2 hour motorway drive on Sunday and since the furthest I have driven this Fiat is 20 miles I'm a bit nervous. How fast do things comfortably cruise at without thrashing the engine to bits?
The oil looks a bit black so was going to do an oil change on Saturday but I'm considering holding off on the filter clean out due to not having an O ring yet (its on order) and being s**t scared of something braking and being left without a working car at all.
Oil wise I've got a spare can of good quality 20/50 mineral and I think I have some 15/40 somewhere. If I use the 20/50 is this going to be OK in this engine?
Rusty recommends synthetic but as this oil is only going to be in for 2000 miles/3 months at most, what are the thoughts of the collective?
Cheers all
Matt
Re: Sole transport
« Reply #1 on: April 10, 2014, 09:47:09 PM »
Depends on hills and wind. My BIS will happily do around 70 for as long as I have ever needed it to on flat with no wind. It doesn't like crosswinds at that speed though, and take care passing lorries.
Marc
gammakeith
Re: Sole transport
« Reply #2 on: April 10, 2014, 09:50:14 PM »
Pray..... :D  My Alfa was off the road while I was doing the suspension.  Thus, the Fiat was our main transport for a couple of days.  Guess what.....the starter solenoid packed up at the station when picking up the eldest.  Fortunately it bump started OK but the car is clearly showing no gratitude for all the time I have spent on it recently.
Seriously though, don't worry too much.  The Fiat was designed for normal mineral oil.  Synthetic is great stuff but if you change your oil regularly it won't make much difference.  20/50 may not be ideal in the depths of winter but will be fine for a motorway thrash in the Spring.  From my limited experience, our BIS seems most relaxed at about 50 mph.  However, ours didn't blow up after 50 miles on the M1 at close to flat out though I wouldn't call the experience comfortable.  My wife has complained of deafness ever since......
Keith
Kowalski
Re: Sole transport
« Reply #3 on: April 11, 2014, 07:57:33 AM »
Hi Matt,
i recall you're on an aircooled right?
My mother's Personal 4 didn't miss a beat in daily urban commuting.
That little engine can stand quite a lot of abuse in standard trim.
Electrics would be my concern: make sure they are tip-top shape.
I agree 50-55 is the comfort zone for long distance travel.
Come on! sort the electrics and enjoy the commute.
« Last Edit: April 11, 2014, 04:43:20 PM by Kowalski »
baron_matt
Re: Sole transport
« Reply #4 on: April 14, 2014, 12:27:52 PM »
Thanks guys for your tips.
Well we had a busy session on the Fiat this weekend and finally replaced the stinking carpet with a nice smart red one. Also fitted new door seals, cleaned the door cards, replaced the stupid bullet door mirrors with some proper Fiat ones that actually work, and fitted some sound proofing mats in the doors.
The new washer pump was a complete fail as it leaked fluid all over the new carpet and fitting Fiat 500 carpet to a 126 is possible but a complete arse, as it is close but not the same shape, still its better than the moldy cats pi55 smelling thing that I dragged out.
I also took a hacksaw to the gear stick and made it 8cm shorter. This makes it much more comfortable to drive as it doesn't pin your leg against the steering wheel and makes for a nicer change.
I've put the oil change on hold until I have the big O rings for the oil filter so that's a job for next weekend.
Both rear wheel bearings have been replaced and according the the local mechanic were in his words "f**ked beyond belief". The car is much quieter now.
The mechanic also gave the car a check with it on the ramp and has confirmed that the front left hand kingpin is also "****ed!" Again these are quotes. He's recommending that I replace the whole stub axle assembly along with the front spring which caused a low whistle and more %%$$%$%$% type expletives to be yelled.
If I replace the stub axle and front spring are there other things that should be changed or would need to be replaced at the same time?
More sound proofing felt is on order to replace the missing bits on the rear shelf and behind the seat and The headlining is on order. Can anyone confirm why no one seems to fit any sound proofing to the engine side of the bulkhead? I'm thinking about fitting the foil type self adhesive sound proofing.
Mics126
Re: Sole transport
« Reply #5 on: April 17, 2014, 09:46:44 PM »
I don,t know the answer to your last question but I can answer your original question about long journeys I have a 650 aircooled engine and i have a rev counter and I know that I went to london and back twise at 70mph which is basicly 5000 rpm and although i made the jouney the exhaust rattled itself to pieces and on the second journey it broke one of the exhast manifold bolts.
But I went to thruxton and kept the car at about 50-56mph (about 3500-4000rpm) and no issues, ran fine and had very good fuel consumption. I live in the paignanton torquay area.
good luck on future journeys.
