Just a quick question for those who have strobe trimmed a BIS before. I hooked mine up today because I have a small flat spot and wanted to see if it was ok. On the BIS there's three pointers on the timing chain case and a notch on the crank pulley/oil filter. One of the pointers is larger than the other two so I take this as the TDC mark. The manual says that at tick over (idle) it should be 10 Degrees before TDC so my question is which pointer is 10 BTDC?
