Author Topic: Another electronic ignition thread - bis?  (Read 1231 times)
poxxxy
« on: March 09, 2014, 10:33:41 PM »
So weather is picking up and time to start work on the 126 and try and get it on the road! Just looking at replacing points/condenser and then came across all the electronic ignition threads... varying in cost from £30-40 it seems at the moment... will they all do the same job and all require the same modification to fit?
kev126
  • Built not bought
Re: Another electronic ignition thread - bis?
« Reply #1 on: March 25, 2014, 07:50:29 PM »
They are all the same as they DON'T make them for BIS. I attempted it once but couldn't suss the wiring - reverted back to points which were fine in the first place. Holes must be drilled on the points plates and tapped to M3 I think? The ring which goes onto the cam must be filed out. I still have my kit (ring filed out perfectly) in my room somewhere if you'd like to try. Just send a few quid my way and I can post it. Sold my bis at the weekend so I won't be needing it at all anymore.
1989 Fiat 126 BIS
