Author Topic: Reverse eye leaf spring on a BIS  (Read 3218 times)
« on: February 25, 2014, 06:25:01 PM »
Does anyone know if the 500/air cooled reverse eye spring will fit a BIS? Just read a link that suggested that it didn't although I can't see why? Ricambio sell one and it looks (Dimentionally) the same? Can anyone conferm this?
Ministig
Re: Reverse eye leaf spring on a BIS
« Reply #1 on: February 27, 2014, 09:06:06 AM »
I've got one on mine and it fits fine  :)
« Reply #2 on: February 27, 2014, 06:35:06 PM »
Cheers ministig I was hoping it would  :) were you happy with the results? How much did it lower the car?
Ministig
« Reply #3 on: March 01, 2014, 11:21:20 AM »
Yes. The results were great and it will lower it by about 35mm
Bambino126
« Reply #4 on: March 01, 2014, 12:58:44 PM »
My leaf spring is knackered, so I'm considering this.
Does it give a stiffer ride, or just the same?
Did you have any problems with ground clearance, eg, grounding on speed humps?
Were there any adverse effects? Did it change the cars wheel camber? Did it affect tyre wear?
« Reply #5 on: March 01, 2014, 08:44:27 PM »
Well I took the plunge and bought one. It arrived yesterday and I fitted it today. The car is notably lower but not "sump scrubbing" low - in fact if you didn't know it had one fitted you may not notice. A test run around the block reveled that the stiffness is about the same as the standard spring which is not surprising as it's essentially the standard spring but with the eye bolts turned upside down. I bought mine from Ricambio and it came super quick and was very well made with new bushes fitted so it was ready to fit. To early to tell about tyre wear but the camber seems to be the same  :)
Scarlettkitten
« Reply #6 on: March 01, 2014, 09:24:27 PM »
Interesting, I've got a 5 leaf reversed eye spring from Poland to fit soon.  Be interesting to see what difference it makes.
« Last Edit: March 01, 2014, 09:29:01 PM by Scarlettkitten »
1990 126 BIS
« Reply #7 on: March 01, 2014, 10:49:26 PM »
Ohhhh I like! You must stick some photos up when it's done  :)
Scarlettkitten
« Reply #8 on: March 01, 2014, 11:13:26 PM »
Thanks, will do :)
1990 126 BIS
poxxxy
« Reply #9 on: March 10, 2014, 12:53:49 AM »
Yes very nice Scarlett :), Can you share link on where to get them?
