Author Topic: Fiat 126 meets AA part 2  (Read 2861 times)
philippa
« on: April 23, 2006, 03:10:42 PM »
hello all
Hi has u all know my little 126 broke down on the way to the wiltshire rally, to my suprise it happend again. the car just looses power then when i stop wont move. The the AA picked me up and took me home he took the car for a drive and it was fine again. I have spoken to chris and david about it and they have given me some great advie so i will keep an eye on it to try and solve the problem.
I have photos of the car being towed away but still cant figure out how to put them in the forum.
Thanks philippa
« Reply #1 on: April 23, 2006, 03:19:58 PM »
wallopadonkey
« Reply #2 on: April 23, 2006, 06:34:50 PM »
mine did that the 2 connections on the coil were loose first then the fuel pump works in fits and starts the running for a bit was down to the fuel pump the intermittant starting was due to the loose coil leads
dave
fiatfsm
« Reply #3 on: April 24, 2006, 08:53:55 AM »
Hope it gets sorted, but hey, looks mighty fine even behind the tow truck :wink:
PaulB
« Reply #4 on: April 24, 2006, 09:55:40 AM »
I had this twice - the first was oil leaking and causing a short at the starter motor. the second was an airleak at the carb. However, there are some more likely causes.
Firstly follow Dave's advice and look for a loose connection.
If the car stalls once the choke is off, then its likely to be grot in the main jet.
If the car runs without choke okay (no backfiring, etc) then suspect ignition. Try swapping the condenser on the distributor - you should keep a spare in the car anyway. They are available from most parts shops.
If the coil feels very hot after a 10-15 minute drive then swap that.
If you have a volt meter then check the voltage to the coil - your regulator on the alternator could be faulty giving too many volts, or if you've a twin spark coil, the ballast resistor might be missing or faulty (I am not familiar with the BIS, but on the aircooler its above the spare wheel). Voltage at the coil should be about 12V after about ten minutes if there's a resistor. With a standard coil and no resistor then 14V is quite usual. Above that and things will be getting hot and will malfunction. When they cool, they'll work again.
As a long shot, check the valve clearances as they could be causing overheating.
The AA will only collect you so many times a year so if you have the time and its safe, leave the car well alone to cool and retry before calling them out.
ps For my sins I used to live in Shawforth (nr Whitworth) for a while. Now I'm on the right side of the hills, but not too far off if you need some help. BIS are a bit of a black art though. There are a couple of club members in West Yorks who may know more about steam power than me.
philippa
hi paul
« Reply #5 on: April 28, 2006, 05:46:16 PM »
hi paul
Thanks for the advice havent risked going out in it again yet, will have to go and break down some where again thou just to solve the problem. and yes i might need your help i dont have a clue. will check all the things you have suggested thou it as to be something very simple but causing a major problem.
Thanks philippa
