Author Topic: rev counter  (Read 6081 times)
rev counter
« on: April 21, 2006, 06:59:18 PM »
anyone know of a supplier/s that offer pod mounted (2 cyl) rev counter?,seen loads of dash mounted 500 ones but nothing seperate,all come as a set of instruments,i just want the rev counter (before i blow the oil plugs out of my crankshaft.... :shock: ....) to mount on top of the dash.........second hand would do as well
hudsonhenry
    • http://www.retro500.com
rev counter
« Reply #1 on: April 21, 2006, 08:40:58 PM »
I used one from a Harley v twin, another fine ebay purchase!!!
Bruce
rev counter
« Reply #2 on: April 21, 2006, 08:59:26 PM »
years ago i had one in my reliant robin, it was electronic and worked of the iginition system, it counted the number of sparks and worked out the revs from that. it could be mounted in a pod i guess. there was a stwitch on the back so as you could select the number of cylinders so the revs where right. i would imagine it should be easy to find somethin similar on ebay. Off hand the Moto Morini v twin had an electronic tacho that would work, you'd just need to sort out a mounting.
rev counter
« Reply #3 on: April 22, 2006, 08:37:38 AM »
thanks for the input guys,i had thought of harley etc,but was wondering about the ignition set up on the fiat,ie,would it be compatible........sparks and pc's are not my forte... :oops: (taken me a week or so to figure out and fit a pole reverse switch to the actuator on my rear boot lid,yet just a day to cut/shut and figure the geometry).
i guess if i can get one cheap enough it wont matter if i fry it  :lol:
william
rev counter
« Reply #4 on: April 23, 2006, 09:23:33 AM »
rev counters are always wrong on a 126 it is cos they are italian
Chris Lakin's Nephew
richard
rev counters ..
« Reply #5 on: April 23, 2006, 10:44:20 AM »
i dont know whether it applies to all cars .
but i used to fit rev counters quite easy onto my mini , using only a few wires ..
then i just mounted it on the dash board .. simple but effective ..
rev counter
« Reply #6 on: April 23, 2006, 12:13:35 PM »
i know richard,but try finding a 2 CYLINDER car rev counter........they are all 4-6-8..............im gone try and get a harley one,also being a bike(waterproof) one i will have the choice of ''hood mounting'' it.had that on my pontiac grands prix............ :cool:
richard
rev counter
« Reply #7 on: April 23, 2006, 12:28:25 PM »
oh yup didnt realise the 4 cyl thing ...
hehe
good luck with it let me know how you get on
gregs656
rev counter
« Reply #8 on: April 23, 2006, 12:50:33 PM »
harley would should be easy enough to get hold of, but there are lots of other V Twins that would be suitable.
get down your local scrappy (you got em over there?), ther'll be summut
The Hunt Continues. . .
PaulB
rev counter
« Reply #9 on: April 23, 2006, 08:42:00 PM »
You can usually modify rev counters that have a cylinder sector switch (4, 6 8) - there's an explanation on the Blitz site and i've come across the same tip on 2CV sites as well. I expect Maplins would have the right resistor.
I've emailed this  (slightly mad) Dutch guy for instructions in Dutch (!) but even a list of suitable tachos from him would be helpful as new tachos are extortion.
I'll let you know what I get back.
http://korridor.se/aryan/acadiane/
It seems this guy has a turbocharged 2CV...
PaulB
rev counter
« Reply #10 on: April 23, 2006, 09:13:01 PM »
Well Aryan is quick off the mark. he can supply 2 cylinder tachos for 40 euros. I've asked for a picture.
He uses the same method as the Blitz site when modding 4/6/8 cylinder ones.
Anyone interested in a dutch tacho? It would make sense to get a few sent over at once.
he can get other meters as well. he has a site selling electronic ignitionfor classics (sadly not fiats) at
http://www.123ignition.se/
VESPA210CM3
rev counter
« Reply #11 on: April 24, 2006, 03:46:30 PM »
Quote from: "hudsonhenry"
Can you put here a photo of the revcounter installed ?
is for FIAT 126 BIS ... VESPA & LAMBRETTA !
PaulB
rev counter
« Reply #12 on: April 24, 2006, 09:54:03 PM »
Here's the 40 euro one from holland - 80mm, external
slammed 66
rev counter
« Reply #13 on: May 20, 2006, 01:36:32 PM »
How far should a stock aircooled be revved to without causing crank damage etc?
PaulB
rev counter
« Reply #14 on: May 20, 2006, 02:10:12 PM »
If its stock and well maintained, you can safely drive foot to the floor. The stock set up is so restrictive, you'd be lucky to get much above 4500 rpm. Obviously, don't rev the engine wildly when its not moving the car....
