Author Topic: MOT  (Read 1305 times)
essex southend
MOT
« on: January 31, 2014, 03:13:47 PM »
Hello all
Tomorrow I am putting Fanny through her first MOT as I need the mot before I can register her with the DVLA.
I know that it will fail on the following,  windscreen washer, horn, front headlights ( thanks to Bar Vitelli I have them but not had time to fit them ) also reversing lights which I am not sure will be part of the test.
If it fails on anything else who knows but I will let you all know.
Bar Vitelli
Re: MOT
« Reply #1 on: January 31, 2014, 03:17:41 PM »
Good luck, Ray, at least you'll have a things to do list to work through if it does not pass.
Every cloud has one...
essex southend
Re: MOT
« Reply #2 on: January 31, 2014, 03:22:55 PM »
Thanks,  it is the weather that is holding me up as I wanted to do the little jobs first but at least I can have a list to tick off things to do.
essex southend
Re: MOT
« Reply #3 on: February 01, 2014, 02:28:11 PM »
Back from the MOT and here is the list.
n/s stop light
o/s stop light
o/s indicator
horn
n/s head lamp
o/s head lamp
Passenger seat can't be secured
windscreen washer
n/s shock bush worn
o/s shock bush worn
n/s rear brake needs adjusting
o/s rear brake needs adjusting
parking brake needs adjusting
o/s rear joint bearing has excessive play.
All in all a majority of the jobs I can do with ease.
He said the body work is good and the underneath is the best he has seen on a fiat so well happy.
