the only one I can see on 126fan is the gearbox side, which is not the one I'm after. http://www.126fan.sk/eshop/index.php?main_page=product_info&cPath=2&products_id=49 Hi, Andyzeetec, Axle gerstl have what you want. on the left of there page click on Transmission & gearshift. then click gearshift. On page 1. look for Rubber packing for shifter shaft ( tunnel exit). FOR FIAT 500R. 3.30 EUROS. This rubber is the same as your photo. Regards Gren. uote]
Quote from: andyzeetec on January 31, 2014, 05:21:58 PMthe only one I can see on 126fan is the gearbox side, which is not the one I'm after. http://www.126fan.sk/eshop/index.php?main_page=product_info&cPath=2&products_id=49 Hi, Andyzeetec, Axle gerstl have what you want. on the left of there page click on Transmission & gearshift. then click gearshift. On page 1. look for Rubber packing for shifter shaft ( tunnel exit). FOR FIAT 500R. 3.30 EUROS. This rubber is the same as your photo. Regards Gren. uote]Nice one, thanks Gren http://webshop.fiat500126.com/katalog/artikelinfo/6964/rubber_packings_for_shifter_shaft_tunnel_exit
