Author Topic: here we go  (Read 1329 times)
the duke of 126
here we go
« on: January 27, 2014, 05:48:58 PM »
so hey the bis needs new driveshaft gaiters on the inner side , so I thought I might as well check everything else out while he is up on axle stands , makes sense eh?
well turns out the engine sump seal leaks like a tap , and on the gearbox there is fresh red oil and fresh engine oil , leading me to believe maybe the end oil seal has gone.
so what the hell eh ? might as well take the engine out and then the gearbox will be easier to extract.
2 hrs later engine ready to drop out, rad out starter off alternator out, airbox off, then I stand back and think "how did I get to this point"?
anyhow , what do you think ? is is best to just buy a engine seal kit ? or just buy the sump seal etc ? I don't want to do the head gasket as it has had a cooper one put on with no probs since.
lastly is rimcambo the best place for parts?
Re: here we go
« Reply #1 on: January 27, 2014, 06:50:51 PM »
Now you have got to stand back and ask the question "Can I get all this stuff back in?"  ;D
Good luck and it sounds like you are the guy for the job.
Check the back of the flywheel for traces of oil in case the engine oil seal is leaking.
Also we are so used to going to specialist parts suppliers that we often overlook the Fiat main agents & local motor factors. I wanted a set of undersize big end bearings last week , rang the local Motor Parts Direct and they found me a set within minutes about £5 cheaper than Ricambio and no postage to add on  :)
the duke of 126
Re: here we go
« Reply #2 on: January 30, 2014, 12:08:43 AM »
Got the engine out today ,took the flywheel off ,no leaks from seal , I think the oil was from the breather pipe being loose , I fixed that a while back, going to take the gearbox out at the weekend, took lots of pics as I went to catalog placement of parsts ,wires etc .
