Fiat 126 Chat
Are the rear rubber bump stops the same on the BIS as the aircooled 126?
Pages: [
Topic: Are the rear rubber bump stops the same on the BIS as the aircooled 126? (Read 1354 times)
magnumpi
Newbie
on:
January 17, 2014, 10:37:32 PM »
Hi all does anyone no if the rear rubber bump stops on the BIS the same as an air cooled 126?
Captain Tracteur
Member
Le cowboy from Hell! :)
Re: Are the rear rubber bump stops the same on the BIS as the aircooled 126?
Reply #1 on:
January 19, 2014, 09:59:23 PM »
No, it's different. Originally the BIS is equipped with this one:
http://www.ebay.it/itm/7688142-PARACOLPO-IN-GOMMA-SOSPENSIONE-POSTERIORE-FIAT-126-126BIS-/151209460966
But I think you can easily fit the AC's snowman-shaped one, its a lot more easier to source.
Classic, not plastic
magnumpi
Newbie
Reply #2 on:
January 20, 2014, 06:41:44 PM »
I see the Bis one is push in where the air cooled is threaded.
Thank you for your help
Scarlettkitten
Reply #3 on:
January 20, 2014, 07:29:16 PM »
I've just knocked one off my BIS, they seem expensive for what they are :O
1990 126 BIS
Pages: [
Fiat 126 Chat
