Author Topic: Changing the fuel tank  (Read 2039 times)
DeVilleChris
    • Club 126 UK
« on: January 10, 2014, 08:02:15 PM »
Hi all, thinking of changing the fuel tank on my DeVille tomorrow. Any advice tips? From people who have done it before?
Thanks in advance
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
gammakeith
Re: Changing the fuel tank
« Reply #1 on: January 10, 2014, 08:34:29 PM »
Don't underseal and waxoyl before refitting.  I did and it made a grotty job much worse!   :D
Hardest bit is getting the fuel filler hose on.  I'm not sure what is easiest way to do this...
Keith
« Reply #2 on: January 11, 2014, 06:55:46 AM »
I have done this job a number of times and always hated it as getting the filler hose back up in position was always a pain as it is a tight fit in the hole. So last time I had a think about it and ended up squashing the fat top end of the hose and holding it in with a cable tie. Hose went up through the hole easily then I just snipped off the cable tie and completed the assembly  ;D
Bar Vitelli
« Reply #3 on: January 11, 2014, 07:53:08 AM »
Might be worth checking the fuel sender unit at the same time? I've just ordered one (they are pricey) for Mrs BVs car as the old one was not much more than rust dust.
Every cloud has one...
gammakeith
« Reply #4 on: January 11, 2014, 09:37:59 AM »
That sounds like a good approach.  I left my hose in the correct position with the tank clamped loosely then wiggled and poked the hose onto the tank spigot.  It did work but there is only a small gap to work in and the clip is tricky to get in place.
Keith
DeVilleChris
    • Club 126 UK
« Reply #5 on: January 11, 2014, 11:20:07 AM »
Thanks for the tips guys, what sealer do you recommend for sealing outside the tank to prevent water
DEYAN IYI
« Reply #6 on: January 11, 2014, 12:16:14 PM »
Be nice to the screws ;D Sometimes (really often) one or more of these 3 tends to break.
Use generously WD40 or something similar. When putting back together, apply a thin layer
of grease or technical vaseline on the studs and use self lock nuts (with the plastic inside).
That's how you'll have them rustfree for the next service interventention in 2034  :P
DeVilleChris
    • Club 126 UK
« Reply #7 on: January 12, 2014, 10:37:28 AM »
Thanks for the tips! I changed it last night, my brother and I a good 3 hours because it was the first one I've done but it's a success!!
gammakeith
« Reply #8 on: March 23, 2014, 01:23:22 PM »
I've just wrestled my tank back (again).  This time, I used Grumpy's excellent tip and I managed to get it back on my own.  Much easier than fitting the filler hose with tank in place.  A well earned Karma!
Thanks,
Keith
