Author Topic: Wheel backspacing  (Read 2734 times)
grubscrew
Wheel backspacing
« on: November 29, 2013, 08:09:00 PM »
 Ok ,so which wheels to use. On the 500 Ive nearly finished the car is on jacks at present. The 4 hubs are 126 hubs,as opposed to 500 , with the 98mm PCD.  However the backspacing on 126 hubs is 95mms and on the 500 wheels,(standared ones) it is 85mm. But now I have 4 x adapter plates which effectively allow the 126 hubs to recieve the 500 wheels (with the silly PCD).
   So, by turning the adapter plates, (which are 10mm thick), the other way and bolt them to the hubs , (by doing this they step back a bit by 3mm) I should achieve the desired result, which is 145`s on the 500 rims, inside arches that have been rolled inward to recieve the slightly wider tyres. Well., thats the theory anyway. Mike.
All things Italian.
grubscrew
Re: Wheel backspacing
« Reply #1 on: November 30, 2013, 05:58:32 PM »
  Oh and another thing, the Mille Miglia wheels have a backspacing of 75mm, which means that the wheels are pushed away from the hub by 10mms more than the standard 500 wheels.
 So unless the wheels have been fitted with 135/12 on a standard bodyshell and standard 500 hubs they wont fit. So I have come to the conclusion that standard 126 hubs on a Fiat 500 will,or should take 145/12, (thats without an adapter plate, but with rolled arches), however on  126 hubs (on a Fiat 500) WITH adapter plate, you should be able to fit standard 135/12 Fiat 500 hubs........ Get my drift?
All things Italian.
