155s are a bit wide for 4 inch rims, and 70 profiles in that size would mess your gearing up and make your speedo reading illegal, and may even foul the arches. much better off going for a set of Cinquecento sporting alloy wheels and 165/55 tyres, these are the close match for gearing and speedo, 155/65s are still within limits although not as close a match. if you want to go wider tyres and keep the standard Bis rims, 145/65 13s are an exact match for gearing and speedo.
