Fiat 126 Chat
Fiat 126 Chat
Bump stop
Pages: [
Topic: Bump stop (Read 2979 times)
fiat126fzr
Member
Bump stop
on:
October 17, 2013, 05:59:50 PM »
Has anyone got a water cooled rear suspension bump stop knocking about? That's the type that pushes/slots in to the chassis as opposed to screws in.
simbad
Member
Re: Bump stop
Reply #1 on:
October 19, 2013, 02:08:25 AM »
Excatly what im after too! I can only see the screw type ones on ebay
simbad
Member
Re: Bump stop
Reply #2 on:
October 27, 2013, 11:04:47 AM »
I need one too! Was wondering if I could somehow get a nut to fit on the screw type one instead...
Haven't had a proper look at mine yet to see..
Or maybe just pump some grip fill up there instead
It's Hazey's car, she does let me fix it sometimes
Re: Bump stop
Reply #3 on:
October 27, 2013, 11:08:54 AM »
If you really want bump stops good luck, but if you only need them for the MOT then don't bother, it is only a fail to only have one bump stop, luckily both of mine fell off.
Marc
https://www.facebook.com/marc.coker
http://www.flickr.com/photos/98903134@N05/
Subscribers
Re: Bump stop
Reply #4 on:
October 27, 2013, 04:04:51 PM »
I bought a pair from my local Fiat dealer two years ago. It is the push in type, and it costs £54 (incl VAT) a pair. Part no is F0007688142.
Last Edit: October 27, 2013, 04:07:47 PM by Amateb8
simbad
Member
Re: Bump stop
Reply #5 on:
October 27, 2013, 09:55:12 PM »
Wowzer! 54 quid! ! Bugger that!..so I dont need them then?does the car bottom out much?
I just assumed if I didnt have them it would hit..
Re: Bump stop
Reply #6 on:
October 28, 2013, 07:42:23 AM »
Mine hasn't bottomed out yet, and we often have all four of us on country roads, dirt tracks and hump back bridges. I've even got slightly airborne on a humpback bridge and not bottomed out on landing.
simbad
Member
Re: Bump stop
Reply #7 on:
October 30, 2013, 12:04:49 AM »
In that case im bining the other bumo stop!
fiat126fzr
Member
Re: Bump stop
Reply #8 on:
October 30, 2013, 08:39:31 PM »
Well if you bin your one and it comes out intact I'll buy it off you
Subscribers
Re: Bump stop
Reply #9 on:
October 30, 2013, 08:57:51 PM »
I just welded a nut into the hole and put a bolt in powerflex universal in there-
Subscribers
Re: Bump stop
Reply #10 on:
October 30, 2013, 09:13:15 PM »
In my case, it rarely bottoms out. That said, there are tell-tale signs that it has, and I do not carry rear passengers 100% of the time.
The Alfa Romeo GTV bump stops also fit, but are similarly priced.
fiat126fzr
Member
Re: Bump stop
Reply #11 on:
October 31, 2013, 09:47:02 AM »
If I can't source one I was just planning only welding a nut in and using air cooled ones
fiat126fzr
Member
Re: Bump stop
Reply #12 on:
October 31, 2013, 05:41:52 PM »
My other one fell off today lol so am just going for the economical welding/screw type fitment... Sod paying £54
Administrator
Re: Bump stop
Reply #13 on:
October 31, 2013, 08:12:57 PM »
The easiest way is to go to an exhaust fitting bay with your shocker and get some rubber doughnuts as pictured below, Extend the shocker and choose some that are a tight fit inside the cover
Cut them so you can get them round the absorber center shaft, then push these up into the shock absorber cover this will stop the suspension from bottoming out:thumbup
Pete.
il cavallo piccolo
Pages: [
Fiat 126 Chat
Fiat 126 Chat
Bump stop
