Author Topic: Fiat 600 engine or lancia a112 on fiat 126??  (Read 6798 times)
Lillen97
« on: September 23, 2013, 08:35:55 PM »
Hello!
I just did buy a fiat 126 and have a 4 cylinder engine, What is it for engine? Is it a fiat 600 engine or lancia a112 engine? The diffrent between the fiat 600 and lancia is fiat 600 have 30hp? and lanica 70hp and i dont now?
But the gearbox is finish and i gone get a new one or a reibuld, but can i get a fiat 126 gearbox or do i need some better stuff? Maybe can i buy a 126 gearbox and put some racing clutch or something?
What should i do?
And is 8/39 better then 9/39 gearbox?
Sorry for so many questions  :(
Pictures on the engine i have:
Re: Fiat 600 engine or lancia a112 on fiat 126??
« Reply #1 on: September 23, 2013, 09:13:38 PM »
The engine code should be visible between the exhaust manifold and dipstick. It does look like an A112.
Lillen97
« Reply #2 on: September 24, 2013, 07:50:19 AM »
Hello :) I did find this number but on the right side of the engine, i can look on the other side to today :) But i think it stands L389L37  But i´m not shure. a picture:
What do you think?
« Reply #3 on: September 24, 2013, 08:24:19 AM »
All I can find is your post on forum svezia. This number is probably the unique engine identifier (date of manufacture and line built on ) the code on the other side identifies the engine block. It should say A112AB FIAT. It could be a 127 engine with the A112 head wedged on, so worth checking.
« Last Edit: September 24, 2013, 08:26:30 AM by Hazey-n-Marc »
Lillen97
« Reply #4 on: September 24, 2013, 06:55:37 PM »
Hello Again :) I have check my engine now and it stand´s this :) Do you now some good website whit new performance and anly standard parts for this engine? What car modell are i gone search on when i look for engine parts?
« Reply #5 on: September 24, 2013, 08:52:18 PM »
I think that it is a 1050cc from a 1977 to 1979 Autobianchi A112.
Lillen97
« Reply #6 on: September 24, 2013, 09:25:31 PM »
Okey, do you now any good website´s for parts/tuning? I need a new gearbox in the car, what do you think if i get a new syncro fiat 126 gearbox with some better cluth maybe racing, do you think it will go whit that 1050cc strong engine?
« Reply #7 on: September 25, 2013, 07:59:34 AM »
 You will probably be better of with a Fiat 600 gearbox. Loads of the 600 Abarth replicas use the A112 engine coupled to the standard box.
Lillen97
« Reply #8 on: September 25, 2013, 09:05:46 AM »
Okey, so you think a fiat 600 gearbox is better? And that gearbox fit with no problems in My fiat 126 with a a112 engine?
But it relly hard to find a good fiat 600 gearbox, it cost like 2000 dollar, and a 126 gearbox cost like 7800 euro :/
« Last Edit: September 25, 2013, 09:42:11 AM by Lillen97 »
« Reply #9 on: September 25, 2013, 10:01:06 AM »
 Check out this.
 http://club126uk.co.uk/smf/index.php?topic=6408.225
 Tate is using a 600 gearbox. It`s not a straight swap, but it is stronger than the standard 126 gearbox.
 What gearbox is fitted to your car at the moment? If it is a standard gearbox there must be some sort of adapter plate?
