Author Topic: Temperature gauge and others  (Read 1617 times)
« on: September 17, 2013, 05:20:37 PM »
I drove my 126 Bis at last after about 8 weeks. I thought I'd drive it in the motorway to get it going again. The car started in one go, but it was spewing out a lot of water from the exhaust. I would say, over a liter of water! Strange! Should I be worried with the large amount of water coming out of the exhaust? I checked the oil and it looks normal.
Drove the car for about an hour and turned back - lovely! I noticed the temperature gauge sat at about a quarter. It should normally sit in the middle of the gauge after a short while. Is the thermostat playing up, and need cleaning or replacing?
kev126
  • Built not bought
Re: Temperature gauge and others
« Reply #1 on: September 17, 2013, 05:23:33 PM »
The car would overheat if the thermostat was dodgy, I've removed mine and it does takes little longer to warm up, but the needle of the gauge does get to The middle eventually!
1989 Fiat 126 BIS
« Reply #2 on: September 18, 2013, 10:21:08 AM »
Perhaps my thermostat is stuck in the open position. Should I ignore it? I'll keep a watchful eye of the temp gauge.
Many thanks!
kev126
  • Built not bought
« Reply #3 on: September 18, 2013, 10:34:52 AM »
It won't be that, cutting it out makes it ALWAYS open so it can never get stuck on closed. It sounds like it's something else. Did your 'low coolant' light come on on the dash? Check the condition of your temp sensor in the engine bay - check the connection to the wire, corrosion etc. and just give it a wiggle :)
1989 Fiat 126 BIS
« Reply #4 on: September 18, 2013, 11:07:09 AM »
A litre of water out of the exhaust either means that someone had filled the exhaust with a hose pipe or the head gasket has gone  :$
« Reply #5 on: September 21, 2013, 03:04:50 PM »
The incident must have been a fluke. I drove my car today again, and it did not miss a beat. The temp gauge did go up to just below the middle position.
