Author Topic: modify from TURKEY  (Read 6773 times)
candanoglu
modify from TURKEY
« on: September 02, 2013, 10:54:13 AM »
I bought 1991 FSM650 air cooled.
this photos when I bought first time... 08/2012
I restored and modified step by step
« Last Edit: September 02, 2013, 10:57:01 AM by candanoglu »
candanoglu
Re: modify from TURKEY
« Reply #1 on: September 02, 2013, 10:55:36 AM »
First step..
kev126
  • Built not bought
« Reply #2 on: September 02, 2013, 02:07:10 PM »
A lot of gauges!
1989 Fiat 126 BIS
Seabee1978126
« Reply #3 on: September 04, 2013, 10:16:26 AM »
What size wheels are those? They look quite large, I think the black paint on them makes them look bigger.. That is quite a lot of guages!!
candanoglu
« Reply #4 on: September 04, 2013, 03:18:17 PM »
it's true..black is look big..size is 175/50/13.
gauges.. oil temp,oil press,volt,vacuum and boost.
kev126
  • Built not bought
« Reply #5 on: September 08, 2013, 04:04:33 PM »
What engine is it running? Any more pictures?
1989 Fiat 126 BIS
Bambino126
« Reply #6 on: September 08, 2013, 11:25:08 PM »
Boost? It's turbocharged?
candanoglu
« Reply #7 on: September 09, 2013, 09:41:30 AM »
 motor is second step.I have a Weber 40DCOE and NANNİ manifold but I didn't fix them.I made headres and fixed electronic ignition kit, msd 8,5mm spark cable and NGK iridium spark.I think I will use 40/80 camshaft and high compression piston...Finally maybe I can try NOS..
kit car :)
kev126
  • Built not bought
« Reply #8 on: September 09, 2013, 10:38:58 AM »
Nos? Insane!
What are the alloy wheel specs? They look like 13" x 7j
Do you know the ET / offset? :)
1989 Fiat 126 BIS
candanoglu
« Reply #9 on: September 09, 2013, 02:41:35 PM »
Nos? Insane!
6,5 x 13 ..but ı don't know offset spec
kev126
  • Built not bought
« Reply #10 on: September 09, 2013, 04:59:30 PM »
Thanks! Any info on the make/model? I'm trying to work out what will fit without having to buy and test. Keep this build updated :)
1989 Fiat 126 BIS
candanoglu
« Reply #11 on: October 28, 2013, 11:52:07 AM »
candanoglu
« Reply #12 on: December 25, 2013, 02:57:30 PM »
wheel arches...
candanoglu
« Reply #13 on: January 02, 2014, 07:33:05 AM »
[/QUOTE]
candanoglu
« Reply #14 on: January 19, 2014, 08:54:27 PM »
