Author Topic: Transporting a 126 & 500  (Read 5043 times)
« on: August 29, 2013, 09:09:34 AM »
Can anyone recommend a company for moving a small fiat?
I need to move my 126 & 500 from Slough to Newbury (about 45miles) and sadly neither are running at the moment.
I’ve had quotes from Shiply to move both cars for around £150, but last time I had one moved it was £40, so that doesn’t add up to me!
I have a towbar and am also looking at the possibility of renting a car trailer, although they seem to be around £50 per day.
I have thought about using a van, but the only van I can borrow is a Movano which has a narrow track. Distance between wheel arches is 1286mm. On my 500, the widest point of the rear tyres is approximately 1280mm. That’s a bit too snug for my liking.
Any ideas or suggestions?
Re: Transporting a 126 & 500
« Reply #1 on: August 30, 2013, 08:45:33 AM »
I use a towing a frame. Took my 126 to retro rides and back with ni problems.
« Reply #2 on: August 30, 2013, 11:35:24 AM »
Yes I remember.
I have been looking into that and I think it's the best option.
I had initially thought that cars towed with an A-frame had to be taxed Mot’d and insured.
However, according to the department for transport:
‘When an “A” frame is attached to a vehicle (e.g. a motor car) and towed by a motor vehicle (e.g. motorhome) we believe the “A” frame and the car become a single unit and as such are classified in legislation as a trailer. As a consequence the car and “A” frame are required to meet the technical requirements for trailers when used on the road in Great Britain.’
Under this legislation a (new) lightboard covers all the lighting, reflector and number plate requirements of a trailer.
As the trailer (“A” frame + car combination) is under 750Kg there is no requirement for brakes.
I have read interpretations of this legislation that state that if the trailer is fitted with brakes (irrespective of weight) then the brakes must be working. Therefore - since the towed car has brakes, they must be working.  Well, they do work, but they need a foot to operate them, and I cannot do that because I am not permitted to carry a passenger in the towed vehicle, because it is now a trailer!
There are companies that sell pedal actuator devices that use inertia (presumably an accelerometer) to detect braking and then apply braking on the towed vehicle. These are becoming common amongst motorhome owners, although there is no legislation governing these devices, which is concerning for a braking system. The fact that they exist has driven the perception that they are now a requirement, but they are not specifically mention in the legislation.
As yet I have found no legaI precedents either way so I am happy to use the system as it is. The ‘trailer’ is less than 750Kg and does no need to be braked.
This, however, is my opinion, and not my advice you should conduct your own research before making your own decision!
« Reply #3 on: August 30, 2013, 12:08:39 PM »
Do they work, it might be cheaper to have them both fail an mot, book em in near where you want to get them to, you could even try telling the garage why you are doing it, they might be rather kind about the whole thing.
« Reply #4 on: August 30, 2013, 12:14:24 PM »
My understanding of the MOT scenario is that you are permitted to travel to the nearest MOT station. I'm moving about 45 miles away and would have to travel on the M4. No amount of police discretion will allow that!
« Reply #5 on: August 30, 2013, 12:28:24 PM »
It definitely isn't the nearset MOT station, and even if it was you could point out that it was going to your nearest MOT station, but I do agree that the M4 may be pushing it a bit.
Any banger racers nearby, offer them some cash to move them, they are often up for making a quick buck.
I have put a shout out on a few car club pages, will let you know if anyone comes forward.
« Last Edit: August 30, 2013, 12:36:25 PM by Hazey-n-Marc »
« Reply #6 on: August 30, 2013, 12:45:21 PM »
I've done a quick check and it looks like you're right about it not being the nearest station. I've only ever driven 3 miles or so to my prefered tester. I don't fancy risking any further than that.
I think the A-frame is the way forward. You could tow all day with one of those!
« Reply #7 on: August 30, 2013, 01:05:21 PM »
Michael if the cars are on a SORN you will need to check the legality of towing. I have been told if the vehicle is on a SORN then no part of it should touch the road, it must be off the ground on a trailer.
« Reply #8 on: August 30, 2013, 01:10:12 PM »
It is illegal to tow a vehicle onto a motorway, you are only allowed to tow them off of a motorway if they have broken down on the motorway. Going from one junction to the next might be allowed.
« Reply #9 on: August 30, 2013, 01:14:29 PM »
Hi Ralph. This is not my opinion, it comes from the department for transport through the GOV.UK website.
https://www.gov.uk/towing-with-car/towing-equipment-safety-standards
Hazey - you are right when towing with a rope or fixed bar.
« Reply #10 on: September 03, 2013, 10:50:03 AM »
I towed mine to Retro rides and back no worries.
I towed my 126 when I got it from Loughborough to Southampton no worries.
As long as you cover or remove the number plate, those cameras that check tax will pick up the plate.
Kent126
    • Facebook Profile
« Reply #11 on: September 04, 2013, 02:34:51 PM »
Never used them myself, but you might want to give 'Weenie Fiats' a ring in Swindon. Not too far from you and based down the M4 motorway.
They offer a transport service amongst other things. No idea of cost though.
http://www.weeniefiats.co.uk/about.php
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Bar Vitelli
« Reply #12 on: September 04, 2013, 02:42:52 PM »
I used them once, nice people, but I think they use a van and only have room for 1 car at a time which would increase the petrol cost...
Every cloud has one...
« Reply #13 on: September 04, 2013, 06:30:27 PM »
Shipley.com
« Reply #14 on: September 05, 2013, 09:09:48 AM »
As I said, Shiply were a bit expensive. I have now found a place who will do it for £110, or £70 if he can fit both on in one go!
I had to change my mind about the A-frame. A friend of mine pointed out this legislation:
http://www.legislation.gov.uk/uksi/1986/1078/contents/made
specifically:
"S.87.—(1) Save as provided in paragraph (2), no person shall use, or cause or permit to be used, on a road an unbraked wheeled trailer if—
(b)it is drawn by a vehicle of which the kerbside weight is less than twice the sum of the unladen weight of the trailer and the weight of any load which the trailer is carrying.
Towing my 126 with my golf would mean I need a braked trailer, so I can't do it. I will get an A-frame at some point, but I will need to add brakes to the fiat.
