Author Topic: coil overs  (Read 4336 times)
saamme
coil overs
« on: August 24, 2013, 07:54:22 AM »
hi, fellows. new 126 lover over here.
i have few questions.
which coil overs are the best for 126 and is it difficult to install them?
i want a slammed 126 ;]
thank you ;]
kev126
  • Built not bought
Re: coil overs
« Reply #1 on: August 24, 2013, 11:34:54 AM »
It's not that simple I'm afraid as all 126's have leaf springs on the front. You'll need to modify or buy a reverse eye one, then either put on shorter dampers or find coil overs which fit (you can't buy them for 126)
Do you have an aircooled or a watercooled BIS? Both are different so until we know we can't give much advice. And welcome :)
1989 Fiat 126 BIS
pietschokkenbroek
Re: coil overs
« Reply #2 on: August 24, 2013, 03:40:27 PM »
I'm not sure what the differences are between 500 and 126 ac or bis models regarding the front suspention. So I don't know if this can be of any help..?
http://www.fiat500sport.com/front-and-rear-suspension/road-front-suspension-kit-0479.html
http://www.fiat500ricambi.nl/tuning/Ophanging
saamme
Re: coil overs
« Reply #3 on: August 25, 2013, 08:08:00 AM »
i dont have one at the moment but im planing to buy aircooled one.
sounds really difficult to me ;/ im not very good at mechanics but im ready to try.
so pietschokkenbroek are these thingies you posted is all i need?
they going to cost me an arm and a leg thought.
kev126
  • Built not bought
Re: coil overs
« Reply #4 on: August 25, 2013, 10:17:06 AM »
You don't NEED them but they will work on an aircooled. Cheapest way is to modify your leaf spring, chop the alloy holder blocks and find shorter dampers. That way you're only paying for the dampers which will be well under £70 odd
For the rear you cut coils off of the spring or buy coil overs for £1,000,000 which probably don't go that low of you're wanting hard slam
1989 Fiat 126 BIS
Re: coil overs
« Reply #5 on: August 25, 2013, 08:38:05 PM »
You can use the rear dampers, from the air cooled as these are shorter, on the front if you lower.
dom.kellett
Re: coil overs
« Reply #6 on: November 03, 2014, 07:37:51 PM »
So what is the cheapest way to lower my bis? I am going to be putting it on coilovers as soon as I can afford it :) but I'm wanting to cheaply lower it to get the looks and feel of it lower :)
Re: coil overs
« Reply #7 on: November 03, 2014, 08:19:09 PM »
The cheapest........ Chop a coil out the rears and flip one of the front leafs over (or remove one but it will be as bouncy as hell) doesn't cost a penny
dom.kellett
Re: coil overs
« Reply #8 on: November 03, 2014, 09:11:43 PM »
I will try just that this weekend :)
