Author Topic: Mileometer has stopped today at 15K  (Read 2796 times)
JonW126
« on: July 03, 2013, 06:48:30 PM »
Took the pocket rocket out fora spn today and the mileometer has stopped almost bang on 15k miles..... I zero'd the top mileometer and that is working perfectly but the main mileometer has now stopped...... Anyone else had thishappen ?
Need a fix ASAP .....
Kent126
    • Facebook Profile
Re: Mileometer has stopped today at 15K
« Reply #1 on: July 03, 2013, 08:52:26 PM »
Don't worry, 15k is a nice low figure! When you come to sell it, it will add value!  ;D
Sorry  :$ very naughty of me.
Not happened to me, probably the cable is shot. Never replaced one, but cant imagine its too hard. They are fairly cheap too.
Other than that, hows the car?  ;D
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
JonW126
« Reply #2 on: July 03, 2013, 09:16:23 PM »
It's mint Tom ...  After spending a chunk of cash with Day & Whites it runs like a dream.
Tomorrow think I'll detail her again as I've not much else to do.
JonW126
« Reply #3 on: July 03, 2013, 09:42:57 PM »
Anyone know how to get the dash cluster off and apart ?
Step by step guide available anywhere ???
Kent126
    • Facebook Profile
« Reply #4 on: July 03, 2013, 10:08:23 PM »
There is an instrument panel removal guide in the subscribers section  ;D
Tom
JonW126
« Reply #5 on: July 04, 2013, 09:58:48 AM »
Tom
The linky doesnt work.... >:( says an error:
Not Found
The requested URL /126instrumentpanel.pdf was not found on this server.
Apache Server at fiat126clubuk.freepgs.com Port 80
wsmitwil
« Reply #6 on: July 04, 2013, 12:21:14 PM »
I think you have to be a subscriber to get to it
But from memory, to get it off it's the screws in the front and then behind a rubber gromet behind the heater you can take the speedo cable off, I think the heater has to come of aswell as the speedo cable it quite tight and inaccsessable
I did take one appart but for spare parts, the milometer is behind four tamper proof screws I think
fiats forever
Kent126
    • Facebook Profile
« Reply #7 on: July 04, 2013, 05:01:29 PM »
Oh the link doesn't seem to work for me either  :o :o
Tom
grubscrew
« Reply #8 on: July 04, 2013, 05:36:15 PM »
  Have you checked it has`nt come undone at the gearbox end ?
All things Italian.
JonW126
« Reply #9 on: July 04, 2013, 06:15:09 PM »
I would if I knew where to look ???
Appreciate some guidance please if you could
« Reply #10 on: July 04, 2013, 09:17:29 PM »
"Mileometer has stopped today at 15K" Yeah yeah, that's what they all say  ;D
grubscrew
« Reply #11 on: July 05, 2013, 02:39:59 PM »
look under the car between the front/rear wheels at the nearside; at the end of the gearbox (the end nearest the front of the car), and you will see a black/silver thick cable (biro thick size ) held on , or it should be, with a ring nut. You could undo the nut  and with a slight pull towards the font of the car it should reveal an inner cable which may or may not be broken.
All things Italian.
