Author Topic: Bis lowering springs  (Read 2785 times)
Ministig
« on: June 17, 2013, 05:07:47 PM »
I am looking for some lowering springs for my 126 bis.
markymarc
Re: Bis lowering springs
« Reply #1 on: June 18, 2013, 01:08:51 PM »
Why not cut off 1 coil?
Marc
Ministig
« Reply #2 on: June 18, 2013, 05:30:01 PM »
Probably easiest thing to do. Thanks
« Reply #3 on: June 18, 2013, 06:25:59 PM »
rear cut 1 coil out, front cut down the alloy blocks between the body and the leaf by 1mm.. if you need more you'll need to buy a lowered front spring..
Ministig
« Reply #4 on: June 18, 2013, 06:47:46 PM »
« Reply #5 on: June 18, 2013, 08:06:35 PM »
Sorry meant 11mm not 1 :$
Ministig
« Reply #6 on: June 18, 2013, 08:24:23 PM »
Ok thanks  :)
Ministig
« Reply #7 on: June 18, 2013, 10:28:40 PM »
How much would 11mm lower the front by?
« Reply #8 on: June 21, 2013, 11:09:21 PM »
One of the other guys might be able to help here as mine was done on top of a reverse eye spring with a leaf removed and a camber mod..
Ministig
« Reply #9 on: June 22, 2013, 12:35:08 AM »
Thanks my dad has told me to concentrate on getting it going first but I want to know how to get it down on the ground!It is my first car .He has given me wheels he bought as spares for his Uno turbo's-mk 2's both.he also has some Intergrale wheels off his -that are 14 inch which are around.i presume all will fit as same group? Does anyone go down smaller/fatter  route like Germany and now over here with Polo's etc .
Thanks Jacob
