Author Topic: Wheels that fit fiat 126 bis?  (Read 7661 times)
lil bill
« on: June 16, 2013, 10:07:37 PM »
Hi, just got myself a fiat I'm 16 and am restoring it with the help of my dad, however, I'm not sure on what wheels fit? If you have any suggestions I would be very appreciated. Thanks very much ;)
Seabee1978126
Re: Wheels that fit fiat 126 bis?
« Reply #1 on: June 17, 2013, 07:45:37 AM »
I was always a fan of minilite wheels on the 126. Just make sure you get the 4x98 lug pattern! I'm going to be installing these. I believe they're off a 1981 BMW... I'm still just trying to find some good cheap tires! Good luck!
wsmitwil
« Reply #2 on: June 17, 2013, 08:38:58 AM »
Hello and welcome to the club
If you are restoring it I would say keep the steel wheels on, the only bad things about them is they have stupid size tyres
But if you want it custom, wheels from fiats around that age fit, ie 1st generation Punto wheels, cinquacentos or seincentos
I think it always helps if youve got a friendly scrap yard owner who lets you look around their cars to find something,
Hope I've helped
 ;D ;D ;D
« Last Edit: June 17, 2013, 08:41:11 AM by wsmitwil »
fiats forever
lil bill
« Reply #3 on: June 17, 2013, 06:46:39 PM »
Thanks a lot guys should be able to have a more wide search for some now thanks.  ;D ;D ;D
« Reply #4 on: June 17, 2013, 07:39:31 PM »
These are my favourite wheels at the moment Steelies off a BMW E21 :P
lil bill
« Reply #5 on: June 17, 2013, 07:45:26 PM »
Yeah just looked and some are too big I need 13 inch coz I don't want to be adjusting anything really if possible.
« Reply #6 on: June 17, 2013, 08:06:58 PM »
The wheels on the 126 are BMW 13" by 5.1/2 J you do need a set of wobble bolts to fit BMW wheels to a 126 ;D
http://club126uk.co.uk/smf/index.php?topic=8163.0
« Reply #7 on: June 17, 2013, 09:12:32 PM »
Hi lil bill, welcome to you and your 126  :)
I would guess that you have a little time on your hands so you will be able to look around but any 98pcd 13" wheel up to 5.5J should fit without wobble bolts. Depends on the look you are going for but have fun looking and if you buy well you may end up with a "lil bill" at the end  ;D
Seabee1978126
« Reply #8 on: June 18, 2013, 07:12:56 AM »
I'm not needing wobble bolts for the BMW wheels that I will be putting on my 126. I've test fitted them and they're good to go. Maybe it depends on the year BMW?
« Reply #9 on: June 18, 2013, 01:28:31 PM »
 They will most likely be 4x100 if they are BMW wheels. You might not notice the 2mm difference like this.
 Just double check the wheels as it wouldn`t be very safe using them without wobble bolts.
Seabee1978126
« Reply #10 on: June 18, 2013, 04:07:04 PM »
Sounds good. When I get some tires, ill make sure!
GTodd
« Reply #11 on: June 22, 2013, 04:22:00 AM »
Hi, Here's a cheap idea from New Zealand .. if the photo loads. Keep it standard, spray everything silver, and buy some fake abarth wheel cap stickers on Ebay.
kev126
  • Built not bought
« Reply #12 on: June 22, 2013, 02:05:33 PM »
If you use 4 x 100 please make sure you use wobble bolts! If you smash over a huge pothole or similar, the strain on the standard bolt will just be catastrophic causing you a bigger bill than a set of Wobblies!
A far as I'm aware 4x98 don't exist for bmw, the 4 stud wheels are all 4x100 until they moved onto 5 studs for the later models. That is why so many Volkswagen scene kids have bmw BBS wheels all the time.
« Last Edit: June 22, 2013, 02:08:03 PM by kev126 »
1989 Fiat 126 BIS
Seabee1978126
« Reply #13 on: June 23, 2013, 07:50:35 AM »
Right on, does anybody know a good place to order these from? (the wobble bolts)
Seabee1978126
« Reply #14 on: June 23, 2013, 07:55:29 AM »
Also, the more I think about it.. How safe are these?? Just kinda sounds iffy to me..
