Author Topic: Advice on car cleaning / detailing  (Read 5334 times)
Kent126
    • Facebook Profile
« on: June 11, 2013, 10:03:56 PM »
Just wondering if anyone can give me some advice on car cleaning / detailing?
Basically I want to give my '79 deville a damn good going over on the exterior, but I dont really know what products to use. Obviously its white, so it will need some fairly good products and some elbow grease.
I dont want to buy mega expensive stuff, but im equally aware that really cheap stuff will be crap. Some middle of the road products would be ok, but I want to get it really clean and then perhaps try and buff it up as best I can.
Any ideas?
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Re: Advice on car cleaning / detailing
« Reply #1 on: June 11, 2013, 10:06:09 PM »
Elbow grease  ;D
« Last Edit: June 11, 2013, 10:12:18 PM by Hazey-n-Marc »
« Reply #2 on: June 11, 2013, 10:41:55 PM »
A good wash followed by T-Cut (when the car is dry) and then a good Wax/Polish with micro fibre cloths usually does the job.
Bar Vitelli
« Reply #3 on: June 11, 2013, 10:56:54 PM »
I met a chap (club member) at the weekend who said that one way to get the best out of the black bumpers and side impact bars on the DeVille was to use a heat gun on them...not tried it myself (I'd be too scared!) but he used to valet cars and said it was a guaranteed to work.
Apparently the plastic has memory so when it contracts it returns to it's original colour...
Every cloud has one...
Kent126
    • Facebook Profile
« Reply #4 on: June 11, 2013, 11:05:02 PM »
Jon I was just reading your other thread actually, you seem like a bit of a pro. I'm not in any rush, so i could hang on and perhaps pop over and get some lessons?
Im off to Slovakia in two weeks anyway so looks like we will both be busy for a little while.
As long as its shiny for Retro Rides in August!  ;D
Also will get me some of that 'elbow grease' on order!  :P
Tom
Kent126
    • Facebook Profile
« Reply #5 on: June 11, 2013, 11:07:57 PM »
Interesting......do you want to go first though? I'd be too scared!  :$
JonW126
« Reply #6 on: June 11, 2013, 11:16:50 PM »
Tom
Bring it round and leave it on my drive, it'll be done for when you return !
I'm not a pro detailer, I've mates that really are, hence why I have all the stuff and they have shown me processes etc that have helped me learn quicker.
Heat gun use is hit and miss, I've done it but only on large plastic plant pots to test the effect - I have products that bring it back to as new, mine are a testament to that.
You've got my number Tom, give us a shout at your leisure.
fixit
« Reply #7 on: June 12, 2013, 01:14:13 AM »
I recently had to do a grp roof, t cut was not good enough as the roof was very oxidised, just didn't give the result so tried a cutting compound made by car plan which was better and smoothed out the surface
some body shops use farcela
but you could always use a clay bar
then polish
 then apply a final sealing coat of wax
hopefully youll end up with the wet look, and have some karate skills (wax on wax off)
I use micro fibre cloths (but don't wash in fabric conditioner as it stops the microfiber absorbancy)
here are some guides and explanations to what each product does
I added the boat ones to give idea on best electric polisher
http://www.carnaubawaxshop.co.uk/detailing-guides.php
http://www.carnaubawaxshop.co.uk/applying-carnauba-wax.php
http://www.boatus.com/boattech/casey/restore-shine-to-fiberglass.asp
http://www.boat-angling.co.uk/Hints_and_Tips/Howtopolishaboathull.htm
no connection with mentioned
hope this helps
regards f
JonW126
« Reply #8 on: June 12, 2013, 09:14:57 AM »
Exactly Fixit..... Clay bar is a must for the 'first pass', that makes a HUGE difference, then a mild cutting compound, (heavier compound on serious swirl marks/imperfections) then sealant, then waxed and show room shined - should turn out beautiful and bead water terrifically..... But that's just the paint sorted, then we have all the black plastics to play with.....
I've never detailed a White car but I reckon it would turn out wet look with the right products.
futfutfiat
« Reply #9 on: June 12, 2013, 10:51:30 AM »
Hi there guys I agree that the clay bar its a must, best kit to buy is  by Meguires its gives you the full kit for about £30 - 40 depending where you go. In the pack you get special liquid to spray before using the clay bar , then a restoring polish , and a liquid gold polish to finish plus micro fibre cloths and aplicator pads. You would be amazed at the results.
Regarding the plastics ( im that ex valeter lol ) best to practise on an old trim if your unsure, hold the heat gun about 6 inches away and keep moving it slowly until you see colour change. Be aware though that this only works on the grainy type plastics not the shiny stiffer type. Afterwards I recommend the bumber gels rather  than the sprays as the gel seems to soak into the plastic and last longer than sprays which just rest and dry out on the surface. Hope this helps
Kent126
    • Facebook Profile
« Reply #10 on: June 14, 2013, 11:30:08 AM »
Thanks for the info guys, it does all seem a lot more technical then I imagined. I've only ever hand washed a car with a sponge and thats about it!  :$
Looks like I have some learning to do!
Jon I shall give you a shout once I have returned from Slovakia, and perhaps we can have a look at the old beast?
Tom
JonW126
« Reply #11 on: June 15, 2013, 10:02:06 PM »
Ideal Tom.... Sounds like a plan, I'm back in Kent from 1st July so give us a shout anytime after that.
Have fun in Slovakia.....
gason
« Reply #12 on: June 16, 2013, 01:05:32 PM »
washing cars is not one of my best skills
skoda_norman
« Reply #13 on: June 16, 2013, 03:08:26 PM »
My car is white - its a bugger to keep clean. Particularly when you start to look closer and see all the various tar spots. I would recommend a clay bar too - I generally use Auto Glym products and am always very pleased with the results.
« Reply #14 on: June 16, 2013, 08:35:23 PM »
Check out the Auto Express website, under accessories & tires section.They publish a host of car waxes and other detailing products.
http://www.autoexpress.co.uk/accessories-tyres/64419/product-awards-2013-best-waxes-polishes
