Author Topic: Positive Camber!! < Negative Camber!!  (Read 2316 times)
f40fanatic
« on: May 28, 2013, 09:00:36 PM »
My Bid has major positive camber on the back, eww. Anyone know how to straighten them up or even make them negative?
Cheers!
Re: Positive Camber!! < Negative Camber!!
« Reply #1 on: May 28, 2013, 09:44:42 PM »
Lower it!
smallcox
« Reply #2 on: May 30, 2013, 03:41:13 PM »
Hi F40fan,
There are two ways both exceptable in there own right. As above lowering will/may change the camber off the rear axle but if you require a set height then there is very little adjustment built into the standard suspension to allow adjustment even for tracking, I know this as I had this problem myself and could not get the tracking in the required tolerances I required.
The way I adjusted my camber/tracking for the rear suspension was to take the measurements I had and made tapered shims to bolt between the rear arm and hub, therefor changing the setting to what I required.
Bit of a bodge is to fit washer between the arm and hub, ie if fitted to the 2 lower holes the camber will move in the direction you require and by changing the thickness of the washers will gain the required adjustment. As I said I made tappered shims for a better displacement contact area but I know of poeple that have fitted washer on high power cars and had no problem.
It's cheap and easy too ;D
« Last Edit: May 30, 2013, 03:42:51 PM by smallcox »
Ricksy1121
« Reply #3 on: June 06, 2013, 06:39:19 PM »
I was coming on hear to ask the exact same question :) thanks for the answer before I even asked haha.. Ours has had a bit of negative camber since we got it but iv just put minilights on and it looks worse now.. Is taking the hub from the arm tricky or straightforward ??
Ricksy1121
« Reply #4 on: June 06, 2013, 09:11:52 PM »
Now iv drove the car it's settled in and looks a hell of a lot better :)
