Author Topic: Ive got a blister  (Read 1773 times)
Draigflag
  • Got a New Abarth 500 too!
Ive got a blister
« on: May 20, 2013, 10:32:07 PM »
Chap who buffed up the 126 today pointed out a rust bubble/blister which I hadnt noticed, just under the windscreen rubber at the front. Bit gutted as it's the only sign of rust anywhere on the car, and thought I was doing a good job preserving her :(
So what now? Do I just accept it happens on old cars? Or do I attend to it before it becomes part of the cabin ventalation system! Since using the car this year, she has been caught in the odd shower, I guess some water has got trapped under there.
Re: Ive got a blister
« Reply #1 on: May 20, 2013, 10:33:26 PM »
That's where mine has gone as well, I think it really needs to be sorted, it will only get worse.
« Reply #2 on: May 21, 2013, 07:07:31 AM »
To do the job properly the screen needs to come out. Normally the small blister will be bigger when you start picking.
it is the place where most go, sadly.
Draigflag
« Reply #3 on: May 21, 2013, 07:47:57 AM »
Every inside cavity and pannel has been filled with waxoyl. I guess its hard to get under there so it gets neglected. Havnt got the expertise to remove the screen so might have to just keep an eye on it.
« Reply #4 on: May 21, 2013, 07:58:16 AM »
I'm pleased this topic has come up.
Is it best to buy replacement window rubbers and cut the screen out?
wsmitwil
« Reply #5 on: May 21, 2013, 08:54:19 AM »
I've removed a screen twice now 1st time probably took less as there was two people but 2nd time took me 15 mins and 4 screwdrivers to get mine out, you just have to be very careful
A lot easier than most screens
« Last Edit: May 22, 2013, 09:09:13 AM by wsmitwil »
fiats forever
phreak97
  • Niki!
« Reply #6 on: May 21, 2013, 01:57:25 PM »
The windscreen rubber can be reused too, Just make sure to use something like sikaflex windscreen sealant when you put it back in.
The cause of the four common rust spots is the drain pipe doesnt drain properly from the cavity under the seal which wouldnt even get water in it if it sealed properly. Lol
phreak97
fixit
« Reply #7 on: May 21, 2013, 02:10:32 PM »
theres a panel available from ricambio but for lhd the wipers holes need adjustment
try some rust buster from Halfords  or www.rust.co.uk to slow
Draigflag
« Reply #8 on: May 21, 2013, 06:43:27 PM »
Whilst im here, got another niggle. Filled the fuel tank the other night, and the warning light went out, but the needle has stuck on a quarter tank! Tried going round some bends to dislodge, but no joy.
« Reply #9 on: May 21, 2013, 07:10:54 PM »
Sad to hear that you have gone round the bend  :( I guess that makes two of us but I am not surprised if you have filled all of your cavities with waxoyl  :o
As for your original question , I think that it is time for that chap to be replaced. I don't think that he has been buffing properly  :$
