Author Topic: Slow turn over  (Read 2392 times)
Draigflag
  • Got a New Abarth 500 too!
Slow turn over
« on: May 13, 2013, 05:31:22 PM »
Hi chaps. Just recently, the 126 has been turning over really slowly on start up, you know that heart dropping sound when the battery is almost flat and you've got one more go? Well it sounds like that! I know the battery is fully charged, so its not that. Does the starter motor need changing? Or is it a timing issue?
Re: Slow turn over
« Reply #1 on: May 13, 2013, 05:59:24 PM »
Try installing a battery isolator. The gizmo is quite useful particularly if you do not drive the car often. I had the same issue with my yellow Bis. It does not get driven for weeks, particularly during the winter months. When I do decide to drive it, I drive for a short while only, not long enough for the battery to get fully charged. Batteries hate the cold as well, so it deteriorates more so in winter.
Before installing the isolator, get the battery fully charged first. Since installing one, the problem never arose again. It doubles up as an isolator as well. It is also cheap to buy.
kev126
  • Built not bought
Re: Slow turn over
« Reply #2 on: May 13, 2013, 06:38:55 PM »
When I was playing with my timing, this happened when it was too retarded. Try turning the distributor to the right to make it more advanced.
Or you could bump start it to see if it is the starter motor. If it runs fine after bumping, it won't be the timing
1989 Fiat 126 BIS
Draigflag
Re: Slow turn over
« Reply #3 on: May 13, 2013, 07:27:06 PM »
Its weird, once its started and its up and running its fine. Turn it off and on again and its ok again. Will have a play with the timing, but thought I had it set up well.
fixit
Re: Slow turn over
« Reply #4 on: May 13, 2013, 09:31:47 PM »
clean your connection wires there is a white plug near to the battery on the starter
also could be a bad earth
I have no fear and would take starter off to strip down and clean contacts BUT i'm not sure of ye skills so added this ;D
http://webshop.fiat500126.com/katalog/artikelinfo/619/rebuilt_starter_with_electric_magnetic_switch
we have a solar panel on dash board with wires to battery to keep battery charged in 4 years never had to bump off or boost, ;D
http://www.amazon.co.uk/gp/product/B002V9JEF0/ref=noref?ie=UTF8&psc=1&s=automotive
hope this helps
regards f
« Last Edit: May 13, 2013, 09:41:36 PM by fixit »
Draigflag
Re: Slow turn over
« Reply #5 on: May 14, 2013, 07:43:02 AM »
Thanks, will see how it goes :)
Lloyd74
Re: Slow turn over
« Reply #6 on: May 15, 2013, 07:07:28 PM »
if the battery is good check the starter motor contacts and the earth wire to chassis as they may be corroded and stop enough current getting through the starter motor. Doesn't sound like timing issue as you say when its going its fine!
Good luck old boy!
Draigflag
Re: Slow turn over
« Reply #7 on: May 15, 2013, 10:02:47 PM »
Not had a chance to look yet. Used the car tonight, it always starts, it just sounds like its not going to sometimes!
Draigflag
Re: Slow turn over
« Reply #8 on: May 29, 2013, 07:43:50 AM »
So the timing is well out now, wont even start! Just wondering if theres a proper way of setting it up? Loosening the dizzy and turning it left and right doesnt sound very technical to me! What could be causing the timing to change? Its been runnning well lately. Have been messing with the fan belt though, would this affect it?
Re: Slow turn over
« Reply #9 on: May 29, 2013, 10:58:43 AM »
The belt only runs the alternator so shouldn't be of any bother as long as the battery charge light goes off when it is running. When I've been replacing my dizzy after changing/attacking my fuel pump it sometimes does the slow turn over. The dizzy cover screw farthest from the condenser is just to the right of my fuel pump bolt, runs nice now. As long as you mark where the dizzy was when you started (DO NOT LIFT AND TURN) you should be able to put it back where it was. There is a retaining bolt at the base of the dizzy, there is no need to remove the bolt, just loosen it until you can turn the dizzy. it really is worth a go.
Draigflag
Re: Slow turn over
« Reply #10 on: May 29, 2013, 12:58:41 PM »
Will have a tinker later. Got it running that way before, just seems a bit slap dash?! Anyway, glad I got some tools for Xmas :)
Draigflag
Re: Slow turn over
« Reply #11 on: May 29, 2013, 05:33:11 PM »
Got her going, took all of 5 mins! Noticed the rubber elbow joining the air filter to the other box/carb bit hadpopped off, so guess this is why it was running rough as there was no seal perhaps?
Re: Slow turn over
« Reply #12 on: May 29, 2013, 05:44:12 PM »
Shouldn't make any difference to the way it turns over, I haven't got an airbox at all.
Draigflag
Re: Slow turn over
« Reply #13 on: May 31, 2013, 06:45:21 PM »
Seems the timing is set up good now, runs quiet and smooth. But, I have noticed a slight hesitation in the throttle response, you press the go pedal then a millisecond or two later, the engine kicks in!  Could the timing still be off a tad?
Re: Slow turn over
« Reply #14 on: May 31, 2013, 07:10:53 PM »
Might be an airleak at the base of the carb
