Author Topic: 126Bis carb wanted please  (Read 3135 times)
126bisbloke
« on: April 22, 2013, 09:56:18 AM »
After solving a few things over the weekend I decided to check out why my cover over the carb wont stay bolted  down properly . I took the cover off altogether and have noticed the hole for the bolt and the  raised area around it has been wrecked  hence why the bolt wont go in . Has anyone got a good spare carb please :D
kev126
  • Built not bought
Re: 126Bis carb wanted please
« Reply #1 on: April 23, 2013, 01:25:18 PM »
Ooh is it repairable? I'd he inclined to fix it instead of searching for these pricey hens teeth.. Which COULD turn out to be full of problems!
1989 Fiat 126 BIS
126bisbloke
« Reply #2 on: April 23, 2013, 02:20:59 PM »
Well this Thursday I'll attempt to remove the top of the carb and see if it can be drilled out and re-tapped So I'll let you know how I get on I'll take photo's as I go along. Kapphar !!!! I think that's Klingon lol. 8)
kev126
  • Built not bought
« Reply #3 on: April 23, 2013, 03:01:20 PM »
Get some pictures of the problem up on here. When I bought my BIS the bolt which held the cover on had very thin and worn threads. I was going to drill out and retap the hole, but instead I replaced the bolt. I think it can be done just don't get any swarf down the carb!! :)
1989 Fiat 126 BIS
« Reply #4 on: April 23, 2013, 03:59:19 PM »
I am not familiar with the Bis carb although I did buy a brand new Bis in 1989 and the only memory of the carb was that it went into self destruct mode after about 2 years and the carb was held together with araldite . Since then I have rebuilt and rescued many Weber carbs and most stripped threads can be sorted with a helicoil. Retapping is probaly not a good idea but like Kev says if you can get a pic to show the problem  :)
JonW126
« Reply #5 on: April 23, 2013, 08:57:34 PM »
How did you do that ?
Mine has a worn double thread and when undoing the top nut it sometimes sticks so the bottom screw thread undoes so the entire pin comes out.
kev126
  • Built not bought
« Reply #6 on: April 23, 2013, 11:15:06 PM »
That happened to mine. I just use an Allen head bolt and a washer now. That's it!
1989 Fiat 126 BIS
126bisbloke
« Reply #7 on: April 28, 2013, 09:04:23 PM »
 :D Hi guys thanks I was able to locate a  S/H carb and I've also purchased a rebuild kit but I have some info for you good folks, here are the i.d. numbers for the carb.
 It's a Weber 30 DGF 3/150 I I also believe that there is a Solex version which is 30 DID/1 Solex.
And here is a place that dos'e carbs  The Carburettor  Hospital 01702 203286
http://www.carburettorspecialists.com/
Thank you... ;D
